Carburator Packing for b210 and b310 are same ?
From Sri Lanka
Hi Guys
Does the B210 and B310 Carborator packing all same or differ from each other ?
i saw Exhaust Temp Gauge in my B310 what does it all about does it relate to the coolant Temperature or what purpose of it ?what are the reasons to indicate it ?
thanks
regards
sumith
Posted on: 2011/11/11 11:18
Re: Carburator Packing for b210 and b310 are same ?
From Malaysia
AFAIK, some use same carburettor, some use 'different' spec.
i used to have 3 b310, my first and second was 'local spec' (malaysia). they both use same carb as b210. my third B310, which is import model, used slightly different carburetor. yes i have that ex. temp gauge in my import version b310, and idk what is it about. but the carburettor differs. some sort of 'ugraded' version.
Posted on: 2011/11/11 11:48
Yes, the carburetor-to-manifold packing (gasket) is the same
However, the internal carburetor gaskets may differ.
Posted on: 2011/11/11 19:59
Re: Exhaust Temperature Gauge?
Some have a warning light to indicate if the catalytic converter is overheating.
If it is an actual gauge, I believe that is not a factory Datsun item. I've not heard of nor seen one.
Posted on: 2011/11/11 20:01
