« 1 (2) 3 »
Re: F/S CR14DE alloy Micra engine 70kw @ wheels
Posted on: 2011/11/19 10:45
The head pattern is nowhere near close to the A series. There is at least 10mm difference in the bore spacing so rule out any twin cam A series fantasies. The fuel rail is a returnless system and the injectors mount straight into the head right on top of the valves. Very neat. There is alot of potential in one of these engines.
Posted on: 2011/11/19 10:48
From Tasmania
How does the lentgh and height of the engine compare to the A series?? Still got the micra gearbox??
Posted on: 2011/11/19 10:57
Proud member of " The Tasmanian Datsun Owners Group"
It is approximately the same height as an A15 and 1 cm or so longer. It is a front bowled sump too for easy installation. The sump would have to be modified but not too drastically.
Posted on: 2011/11/19 11:05
From Tasmania
is it just the engine do you have the gear box for it??
Posted on: 2011/11/19 11:38
Micra is only auto and FWD. So no gearbox.
Posted on: 2011/11/19 11:51
From Tasmania
Mmmm Im wondering if I can fit it to my FWD gearbox?
Posted on: 2011/11/19 12:02
From Tasmania
can you take a pic or two of the sump and area.
Posted on: 2011/11/19 12:30
From Armidale N.S.W
Yeah to much mod work for me to fit to a 1200 if there was a RWD gearbox that would bolt straight up i would be all over it but i dont have the skills and tools to mod blocks etc. So count me out of this one.
Posted on: 2011/11/19 23:49
73 1200 wagon SOLD
From Central Vic
revhead001 wrote:
The bolt pattern of the engine and doewlls match with the A series and all sorts of useful stuff.
I would be interested If you could post a pic of an A series spacer plate or something on the engine or even a ruler across the bolt pattern etc
Posted on: 2011/11/20 10:08
to buy or not to buy???? OK
This is the reason I have five coupes
« 1 (2) 3 »
