CA18DET what to get for exhaust
From Melbourne, Australia
gday,
booked car in for new exhuast on friday, current is old 1.75"
was thinking 2.5" mandrel bend with cat and some muffler
but wondering what other people have done
this is for a coupe with h190 diff, so i have no idea if 2.5" will fit over the diff? maybe it will need to split into two pipes
im hoping all this will stay over 100mm off the ground
i need to get the car engineered
does anyone know the diameter of the stock silvia exhaust?
the motor is currently stock but after engineering i will prob want to fiddle with it
is 2.5" the normal size or are people using 3"?
i have the maddat 3" dump pipe on the car at the moment, and plan to retain that
Posted on: 2011/11/22 9:02
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: CA18DET what to get for exhaust
Just some straight pipe mate out the side, the man will pass it!
Posted on: 2011/11/22 9:18
Car free
From Sydney, Australia
3 inch. But it's gets a bit noisy and heavy and is difficult to get over the rear axle if you want to run a watts linkage or panhard rod. Above 200kw you start needing 3 inch.
Posted on: 2011/11/22 10:04
Get it flanged so 2 or 2.5 for rwc and 3 for fun lol
Posted on: 2011/11/22 10:43
Not too shy to talk
From Sydney
I am running 3 inch from turbo back to axle.
From axle its flanged and reduced to 2 3/4inch.
I have r31 diff and standard fuel tank,it clears tank and
chassis rail by around 10mm each side..needs to be fixed well to avoid rattles.
I have a magnaflow metal cat and magnaflow muffler,all flanged for easy removal.
car is quite off boost but roars when it comes on.
running 204rwkw.
Make sure you your gearbox mount has big "v" to get pipe closer to body for road clearance and choose an experienced exhaust fitter.
Posted on: 2011/11/22 11:46
