Console & clock
From Seattle ,WA.
I've got a lovely console & was all set to install it into the coupe & when I started to fit the clock to the console it doesn't fit! I think I must be missing some kind of adapter plate/bracket that holds the clock to the console. According to the wiki there's supposed to be something like this : "27389-H2300 SPACER FIXING CLOCK TO CONSOLE BOX"
heres the console & clock
backside - you can see the mount tabs/holes don't line up plus their all the way up against the back side of the console & the mount tabs for the console are at least an 1" away - I assume there has to be some kind of spacer mount thing I'm missing....
Datsun blank/cover & mount
heres a pic of my steering wheel for good measure
Somebody sell me one of those 27389-H2300 spacer thingy's please!!
Thanks.
Evan
Posted on: 2011/11/22 5:52
Re: Console & clock
Looks like your clock originally came from the dash? You're definitely lacking the mounting bracket to fit the console
Posted on: 2011/11/22 9:05
Re: Console & clock
From Perth WA AUS
I'm pretty sure I used the standard console blanking plate bracket on my clock to mount it, did you remove the plastic "Datsun" blanking plate and test for fitment?
Posted on: 2011/11/22 10:35
Datsun 1200 2Dr sedan.
Re: Console & clock
From Seattle ,WA.
I got the clock with a bunch of misc parts I bought a while back so no brackets or anything else with it. The blanking plate wont fit as the depth is too shallow - the clock wont mount & it'd need a hole for the clock ti slip thru to make it work.
Anybody have one of the clock mount brackets? Otherwise I'll improvise & make some mounting tabs.
Posted on: 2011/11/22 16:35
Re: Console & clock
From Perth WA AUS
I'll pull mine apart and take some pics just in case :)
Posted on: 2011/11/23 9:10
Re: Console & clock
From Perth WA AUS
You are totally right, I must have been thinking about a custom fitting I have made in the past to fit the clock with the original blanking mount, it's been a while. Here is a pic of my dodgy mounting bracket :)
jpg  clock.jpg (111.49 KB)
9665_4eccbc0890067.jpg 980X735 px
Posted on: 2011/11/23 9:25
Re: Console & clock
This was mine. Pretty sure it was original before I sold it:
Posted on: 2011/11/23 10:17
Re: Console & clock
From Secret Harbour WA
hey evan i just made a plate to hold mine in just like nige's haha
Posted on: 2011/11/23 11:33
76' B120 GX Style Ute
73' B110 coupe
75' Mini Van
77' Mini Van
71' R100 13B PP i miss it!!! its hiding in my garage in QLD
69' R100 GS Jap Spec
67' Mazda 1500 13b turbo
91' BMW e36 318
Re: Console & clock
love your floor mats evan
Posted on: 2011/11/23 11:34
Re: Console & clock
From Seattle ,WA.
thanks for looking guys, yeah it's a weird plate/mount thing I guess. What the hell is that spring / steel rod for - how does that hold it in?
I like the strap method, seems simpler then my individual mount tab idea I was toying with.
The mats came in the same batch of misc parts I got the clock out of as well as the cowl vents I repaired & sent to Carps. I scrubbed the hell out of the mats then I had the brilliant idea of using SEM bumpercoater paint to change the red inset color on the drivers side......didn't work well, maybe I can scrub the paint out of it again - I liked the red better.
In the infamous words of Herman Cain - oops!
Posted on: 2011/11/23 21:39
