(1) 2 3 4 »
A15 with Stanza 5 Speed, Tailshaft too short??? Please HELP!
From Sydney, NSW
Hi guys,
i have an a15 with a stanza 5 speed bolted up to the back of it,
whacked it in today went to bolt up the tailshaft and its 40mm too short....
had a thought of makeing a spacer at the back where the tailshaft connects to the diff using longer bolts made of a harder steel so they dont brake but was wondering if anyone else knows what i can do? tailshaft out of a stanza or any other datsun? really could use some advice as i dont want to go down the road of getting someone to make a tailshaft up for me,
Dion :)
jpg  2011-11-23 16.53.46.jpg (92.89 KB)
14977_4eccd9495f724.jpg 640X480 px
Posted on: 2011/11/23 11:30
Snapped crank and still smiling, How do I do it? LOL
Re: A15 with Stanza 5 Speed, Tailshaft too short??? Please HELP!
stanza 5 speed on the back of an a15? how? is it a 63a and you swapped the bell housing bits?
also what tailshaft did you use? and what diff do you have?
i have a h150 and an auto 120y tail shaft should have fit but need slight shortening to fit, i have a gap to, not as bad as yours.
Posted on: 2011/11/23 11:33
From Sydney
getting the tailshaft lengthened and balanced is pretty cheap and at least its done properly... tailshaft is the last thing u want to come lose and come off whilst driving
Posted on: 2011/11/23 11:43
That might be because the Stanza diff is bigger and 40mm longer.
If you are using the Stanza tailshaft, try the B210 automatic tailshaft instead.
Posted on: 2011/11/23 20:27
From Armidale N.S.W
My first question would have to be. Are you sure its a stanza five speed ? Not doubting you just that they take a lot to fit to an A series engine coming from a L series engine. Secondly What tailshaft are you trying to fit ? If its the original manual one from the 120y then it aint a stanza five speed.
Posted on: 2011/11/23 21:15
73 1200 wagon SOLD
Yeah, you sure it's a stanza five speed?
Posted on: 2011/11/23 21:51
From Sydney, NSW
yeah definately is a stanza 5 speed, on the side of the bellhousing is 60, but besides that, the guy i bought the engine off posted this up :
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=50870
the gears work like this :
R 2 4
1 3 5 so an auto 120y tailshaft would fit nicely? i guess ill go measure it and go find one at the wreckers
Posted on: 2011/11/23 23:54
60 series were a series not l series. L series were 63 not 60 series.
So 60 series did have a dog leg shift which Is what you have- I have a 63a dogleg l speed but I'm l series infront of it.
I doubt it's an l series as it would still say 63 not 60 on the gear box. Is it cable or hydraulic clutch paddle Arm
Posted on: 2011/11/24 0:30
Yes, 60-series 5-speeds came out of Sunny B310. The first ones were a dogleg pattern.
Posted on: 2011/11/24 0:58
From Armidale N.S.W
Again what tailshaft are you trying to use ? As a standard manual 120y tailshaft to suit your diff either H150 or BW68 should fit. To tell what diff you have a BW68 has an inspection plate on the back with a number of bolts in it H150 just has the oil filler bolt visible on the back.
Posted on: 2011/11/24 1:56
73 1200 wagon SOLD
(1) 2 3 4 »
