Handle Engine RPM With AC on
From Sri Lanka
Hi Guys
What is the recommended RPM a B310(210) with AC On ?
as i know Usually it can idle somewhere around 750rpm But when the AC is on it will not idle on that particuler RPM, do i need to set RPM to a higher level so it always runs faster rpm even i don't AC on or is there any component that can increase engine RPM while AC is on ?
if so what is it called and what is the cost of it ?
thanks
regards
sumith
Posted on: 2011/11/23 15:45
Re: Handle Engine RPM With AC on
From Malaysia
the system is called FICD (fast idle control device). provided your carb already have the diaphragm for the valve? the installation is not very hard.
Posted on: 2011/11/23 15:55
From Sri Lanka
Hi BAKAT
Thanks, can any body help me to identify that in this page over a number
http://datsun1200.com/modules/mediawi ... p?title=Carburetor_Repair
thanks
regards
sumith
Posted on: 2011/11/23 16:23
From Malaysia
i do think its part number 7. you hook the FICD device to vacuum, and the other end, hook it to the air nipple at the part 7.
i might be wrong though.
the FICD device should look something like this.
connect the wire to the compressor, we want the ficd to off when the compressor is off.
after hooking up correctly, you should have two adjustments for idle. aircond off, and aircond on.
Posted on: 2011/11/23 16:45
From Sri Lanka
Hi Bakat
Thanks a lot even thought i have part no 7 in my carb i don't remember i have FICD device attached to this,
so will any 12V ficd device will work for datsun 210, or do i need to go for specific model suitable for 210 ?
thanks
regards
sumith
Posted on: 2011/11/24 3:45
B310 doesn't use FCID. It simply idles a little slower when the A/C is on. For USA, idle is set in Drive at 650 RPM with engine fully warm.
Part #7 is for the Throttle Opener, which should not affect curb idle.
Posted on: 2011/11/24 4:00
From Sri Lanka
hi DD
do you mean that if it is set 650 RPM, it will automatically handle idle speed while ac is on ?
thanks
regards
sumith
Posted on: 2011/11/24 4:18
Let me correct that.
* If the A/C is factory installed, it will use FICD
* If it is dealer-installed, no FICD
Posted on: 2011/11/24 4:46
From Sri Lanka
Hi DD
i understand ,i think it is dealer because i have not notices any thing like FICD on my engine bay, is there any possibility of installing a after market FICD to my 210 or can i manage with little extra rpm like 700 -750 rpm ? what do you suggest ?
thanks
regards
sumith
Posted on: 2011/11/24 4:57
Are you having a problem with the idle speed? If so, try raising it a little.
Or you might fit a generic FICD as Bakat suggests.
The factory B310 FICD actuator is like this:
Posted on: 2011/11/24 5:17
