Brake Lights stopped working
From Brisbane
my brake lights stopped working this afternoon, checked the bulbs and they are all fine maybe my stop switch? i checked it with voltmeter and was reading something...
if its not the stop switch it should be the ground right? i checked that as well...
no broken connection or anything that i know of
the rear lights are working (when parking and headlights are on)
Please advise ASAP as this is my everyday car
will try to find a stop switch anyway tomorrow at the wreckers, do you just turn it counter clockwise with the hex bolt attached to it to remove it?
Posted on: 2004/3/11 12:29
Re: Brake Lights stopped working
From Sydney, Australia
brake switch: check it. Pull it out and check it switches by testing with a multimeter.
check you get 12v to the brake switch. It should always have 12v to it.
check your fuses.
It's not complicated.
Chris
Posted on: 2004/3/11 22:08
From Brisbane
the fuses are good checked that too
mut be the switch, i'll try to get a new one today
Posted on: 2004/3/11 22:13
From Brisbane
tried repco, autobarn and nissan and they dont have any of these switches
that means I have to go to the local wreckers.... and it looks like its going to rain today (dark clouds)
Posted on: 2004/3/12 3:19
It's going to train? Does than mean slow moving, unreliable and filthy dirty "people movers" are going to fall from the sky?
Now that he's edited it..I guess my post no longer makes sense...
Ah well..
Posted on: 2004/3/12 3:58
From Brisbane
what train?
hehehe there you go I edited it "HAPPY JANE?"
Posted on: 2004/3/12 5:35
Don't buy a switch, unless it's bad.
1. Check for 12V on one side of the switch.
If not, it's not the switch ...
2. Disconnect the wires, and check for 0 ohms resistance when the pedal is down. If it doesn't go to 0 or only sometimes goes to zero, yes get a new switch. Go to the wreckers.
Posted on: 2004/3/12 7:13
