worked a12
Anyone know of any worked a12 projects done or for sale? i have just rebuilt mine and i had a piston chip and score the bore pretty badly. so basically im thinking of buying another 12 black, and possibly boring it too put flat top pistons in it with an a14 head. i was also wondering what this operation would cost...
Posted on: 2012/1/15 6:58
Re: worked a12
From sydney.nsw
where are you located. cheers
Posted on: 2012/1/15 7:33
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: worked a12
im in victoria bige. also anyone know of any good condition a12 blocks in vic?
Posted on: 2012/1/15 7:48
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: worked a12
From sydney.nsw
pm'd
Posted on: 2012/1/15 7:57
Re: worked a12
From Warburton vic
I have a a12 in melbourne it is a short motor with a mild wade cam. It has new rings,big end & main bearings 300 bucks would do for it I have a head as well but I dont know what its like.
Cheers mark
P.S its standard bore as well
Posted on: 2012/1/15 13:05
Re: worked a12
sleeve it and save it all
120-150 from footscray engine reco, call Steve
Posted on: 2012/1/16 0:42
Re: worked a12
ok so as im still learning... what would be the chance of boring the a12 out to 1300-1350cc and stroking it? has anyone done this before? possibly with a single weber, otherwise standard a12 carby (i believe the jetting on the a12 carb is bigger than the a14, is this just rubbish or the truth?).
Posted on: 2012/1/17 4:46
1200 Ute - Mild A12
Re: worked a12
look up dodgemans sneaky a12 a14 hybrid its a common thing to use an a14 with counterweights machined to miss the vitals and use later a12 conrods and milled a15 pistons or others.
Heaps of info available already, try the wiki too.
Posted on: 2012/1/17 4:59
