Fitting a DIN-mount radio head unit to the dashboard
DIN-mount radios are the same size as the original, but do not have shafts in the front. Instead they attach by the side of the radio.
First, cut out the facia.
You have to cut out the metal around the radio to fit a modern DIN-chassis receiver:
Rectangle cut larger, radio shaft holes now missing
Compare to an uncut dash:
Fabricate a DIN adapter bracket (or modify a commercial one):
Create a bezel, by modifying the stock radio delete plate:
Carefully cut the center out of the delete plate:
Fit the bezel to the radio:
Finished product:
Posted on: 2012/1/22 0:29
Re: Fitting a DIN-mount radio head unit to the dashboard
From adelaide can post trim worldwide
do we realy need to be hacking up good delete plates please dont do it
donate them to the save the datsun dash for future generations fund or sell them on ebay probably worth more than the sony cd player that will die before the datsun does
Posted on: 2012/1/23 17:30
What else would you use the radio delete plate for?
You could use something else I suppose. Got any ideas?
Posted on: 2012/1/23 18:47
Here in aus hard to find now. Most people binned them im guessing. They are sought for original looking blanking plates. I'm using duct tape, same color and finish as the silver on dash lol.
Simple ugly, light yet effective. Tacho will be mounted in front of most of it do I can see from corner of my eye
Posted on: 2012/1/23 20:39
Edited by unfamilia on 2012/1/23 23:06:19
From gold coast aus
you can get single din pockets you can mount under ashtray that hold the stereo and look tidy no cutting or hacking dash then
Posted on: 2012/1/23 22:07
radio fits well in glovebox and hidden from prying eyes
Posted on: 2012/1/24 0:38
From Las Vegas, NV USA
On my '72 Coupe, it came with an Astrosonix AM radio. Was going to use the trim like the blanking plate was used by DD, but now considering against doing so if there is some form of sacrilege associated. The radio is stuffed, but is there somebody out there who thinks cutting that part up to install a modern head unit would be an unpardonable sin?
Open to suggestions
Posted on: 2012/1/24 4:46
I would do cut one up. As long as you are using it to improve you Datsun, how can it be wrong?
Posted on: 2012/1/24 5:48
From gold coast aus
there is a place up here in brisbane that take original radio
and convert to have aux i think or ipod conection its not cheap but good way to keep original look but still have music
Posted on: 2012/1/24 5:57
You can also buy a modern stereo units brand new with shaft fitment. I think Panasonic makes one single model, the others are specialty brands. These fit in the stock 1200 sheet metal, no cutting required. http://www.crutchfield.com/m_362950/Classic-Car.html
Posted on: 2012/1/24 6:01
