Browsing this Thread:
1 Anonymous Users
Re: A15 runs great but it stops running at random!?!? |
" There are many things that can cause your symptoms. But it is less likely to be electrical (or it would be more erratic), and more likely to be fuel related.
Did it start occuring about the time you replaced the fuel filter? Or what else changed around that time it first started happening? " I changed the filter when this started. Great point! I was not driving my truck when it happened but I will follow up with my employee and get back with you:) Thank you man! "Always check to make sure the tv is plugged in before you go taking it apart;)" Right?
Posted on: 2012/1/29 2:36
could be the anti dieseling solenoid in the side of carb as shown in picture. i had an issue with it wanting to stall randomly and traced it down to that.
So, I changed out solenoid but it still does it. Maybe the wire going to it can be the problem? I still need to do all these other great suggestions but I want as much info as I can get so when I go to check it out I can do them all:)
FYI all you guys, thank you so much for the help!
Posted on: 2012/1/30 17:50
Registered Users Contentmaster Usermaster
Yes, changing out parts is not the way to find the problem. It's easier to test the solenoid valve than to change it.
Have you check all the fuel line connections? Clamps are tight?
Posted on: 2012/1/30 20:17
" Yes, changing out parts is not the way to find the problem. It's easier to test the solenoid valve than to change it.
Have you check all the fuel line connections? Clamps are tight? " All the fuel connections are good and all clamps are tight but, I noticed there are cracks in some of the lines so I am going to change them out.
Posted on: 2012/1/30 20:25
"He who has a glass house should not cast stones."
From Sydney, NSW
could be air leaks, or a #OOPS# box carb, i had the same problem with my a12 replaced the carb and all was good
Posted on: 2012/1/31 2:38
Snapped crank and still smiling, How do I do it? LOL
