« 1 2 (3) 4 5 6 »
Re: What's the most power you can get out of an a15
From melbourne
Yeah great idea.. where bouts in Vic are you ?? is it your dyno ?? The short motor is pretty basic to itemize and price. May vary slightly from engine builder to engine builder. And same with the head. I will see if I can get receipt for my head. Its a H89 recoed with standard everything except HD valve spring and 6 hours of porting. (Or if i didnt hear right- 6 hours labour on whole head) .. Unfortunally my engines are forced and efi. Or I would give it a crack
Posted on: 2012/2/9 11:09
From Sydney
Looks like I'm going the a15 the ca is a headache and a half for engineering
Posted on: 2012/2/9 11:44
Technically you may legally need to engineer an a15 into a 1200 too, they exceed the capacity/power allowance of 15% in vic. Check rta for nsw
Posted on: 2012/2/9 11:47
From sydney.nsw
easy fix a14 block, a15 internals, what they don;t know, BAD LUCK.
Posted on: 2012/2/9 11:52
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Sydney
What would the micks Motorsport engine be worth
Posted on: 2012/2/9 12:00
From sydney
more than what your ca setup would cost from scratch plus engineering..alot more
Posted on: 2012/2/9 12:33
datto 1200 ute a12..low n slow (SOLD)
datto 1200 ute, a15 (SOLD)
fj20 1600 (SOLD)
CURRENT: 1200 Coop SR20de project Sleepin
From melbourne
go sell a kidney.. haha
Posted on: 2012/2/9 12:40
From Sydney
Ok well it was a full build,
Mazda high comp pistons
Cam tech second biggest cam they have for a series
Full head work to matching size of manifold after being ported as well
A crank apparently 1.67 or 1.76l I think it's more 1.6??
Dual springs
All new rockers not sure what they are but not standard..
Copper head gasket
Full shaved head/block
That's what I can think of for the $4300ish
Then twin webbers jetted to 48mm
Electric fuel pump
Electronic ignition
Gimlet drive system
5 speed box
And a shortened Mitsubishi scorpion LSD diff
All the second list was extra
Posted on: 2012/2/9 13:03
From sydney.nsw
is that the same engine you had before that, russell from dominators built.whats it going in.sedan/ute/couple.
Posted on: 2012/2/9 13:10
From Sydney
Nahh new motor again.. I sold the one russel built.. Was never happy with it.. It's in my sedan russels one sold to my uncles mate or some guy my uncle knows that's into speed way.. Using it for a back up motor or something
Posted on: 2012/2/9 13:30
« 1 2 (3) 4 5 6 »
