CA16DE Rear gearbox
From Adelaide South Australia
Hi im going to put my CA16DE into my Datsun120y and was wondering what gearbox im going to need/diff, thanks
Posted on: 2012/2/16 5:57
Re: CA16DE Rear gearbox
rear gearbox? You can convert the 120Y to rear engine by bolting the entire Pulsar front engine/suspension into the back of the 120Y, it will be all custom fabrication, but is certainly possible.
Posted on: 2012/2/16 6:16
You need to find out what the bolt pattern is of the CA16. Then you can work out what you can modify to fit it. The chances of a RWD CA being the same are remote, but stranger things have happenned.
Posted on: 2012/2/16 7:08
vanettes never came with ca only the GA which is different as it closer to the E and A series in that order.
Posted on: 2012/2/16 11:09
D i dont understand your answer, the plate under the bonnet of the car says, CA16DE?
Posted on: 2012/2/16 11:22
aha my i read vanette somewhere sorry.
ca16de same as the 18 and 20 versions
ca18de/t or ca20s/e bellhousings with stumpy 71b box is what most peeps do
Posted on: 2012/2/16 12:27
But how is that going to put the gearbox in the rear? Or if he means RWD gearbox there's a problem as the FWD CA engines have a different bell-pattern than RWD CA engines.
Posted on: 2012/2/16 21:59
The good thing unlike the SR engines all the CA engines whether fitted on fwd or rwd, even the diesel ca17dt will bolt up to any fwd or rwd box. The pattern is exactly the same on all of them and Nissan department in charge of the CA where smart to use distributorless ignition to avoid dizzie issues.
Posted on: 2012/2/16 23:44
Patterns are same, but transmissions are different
Or is this incorrect?
* CA16 uses a smaller clutch & gearbox
* CA18 & CA20 use a factory adapter plate & larger tranmission
Posted on: 2012/2/17 0:06
its a FWD engine, but aparentally its a RWD aswell, so i want to know what RWD gearbox i need to use/diff so i can use it on my datsun120y
Posted on: 2012/2/17 0:51
