ca18det wiring
done a ca18det engine swap but now stuck on the wiring how do you wire the ca18det harness in to the existing wiring
Posted on: 2012/2/27 2:46
Re: ca18det wiring
From MOOROODUC. Victoria
Depends on how far you want to go ....
If in Victoria contact tommo73
If in QLD contact Kev Rowley
I pulled out the whole ute loom and put in the whole silvia loom
Posted on: 2012/2/27 5:08
Re: ca18det wiring
From Melbourne, Australia
there is surprisingly little interaction between 1200 loom and CADET loom, the main work is the relay set to power the ECU and coils
i have a diagram of pen on paper that i have been meaning to turn digital for some time, there is a good thread that tommo wrote with a lot of info though, try searching for it as i have forgotten the name of it
Posted on: 2012/2/27 6:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: ca18det wiring
From Adelaide South Australia
ill be needing some help once i get my CA16 in my datsun 120y, hope its not to much trouble
Posted on: 2012/2/27 7:43
