(1) 2 3 »
My hands smell like gear oil!
From Christchurch NZ
And the stuff is hard to get rid of.
I've pulled apart the 63A cogbox from my 1200. 2nd and 3rd gear syncho had been but a distant memory for quite some time. Then while unleashing the supercharged fury in late Oct last year (And showing off to an out of towner) it shore off the roll pin in the 2-3 selector fork.
I planned to whip it out, and slap in a new pin when I learned that Don was going to be in town just after Xmas. But when I drained the oil, three energizer lugs came out with the oil. So I accepted that more serious repairs were needed.
Upon pulling it apart, I've found that the syncho rings are pretty much shot. I couldn't find the blocker ring to gear tolerance in my book today. (Wasn't looking hard enough)But upon closer inspection, one of the them actually has a crack right through it. And one of the energiser lug springs was broken too.
Given that the rings have been cavatating/slipping on the tapered journals for aaaages, I'm a little reluctant to reuse them with replacement (although likely not new) rings. I still have the remnants of my original A series 63 box. But it was in such a bad way that I sswapped my behlousing over to an entirely new box.
Then I've got an allegedely 90,000km L series 4 speed from a 910 bluey. Somebody on here reckoned that they use the same rings as the 5 speeds. So I may scavenge the blocker rings from that. And even though the gears are on different sides of the selector hub to my dogleg box, (H pattern verses dogleg) they appear to be the same. The ratios are bang on the same. But untill I get the four speed fully stripped and hold the gears side by side in hand, I can't say for sure.
The poor old datto has been sitting on the driveway since oct '11. And I'm starting to get an itchy right foot again.
Posted on: 2012/3/7 8:02
Forced Induction!
Re: My hands smell like gear oil!
From Melbourne AUS
i say throw another box in it and your on your way, scratch that itch!
gear oil stinks, but i prefer it over brake fluid
Posted on: 2012/3/7 8:19
1973 B110 A12
Pee on them they'll smell better!
I'm with Ange but get another 63a and go sic
Other wise the charger will be going to waste!
Posted on: 2012/3/7 8:25
Car free
Pay for don to come back over for a week wit a slab of that kiwi beer, he might build your box for you just don't be whipping anything else out
Posted on: 2012/3/7 8:38
I would but short 63's here are going for the same money as 60 series 5 speeds. ($350-400) And my driveshaft has been set up for that box. So I'm gunna have to fix it.
If it does come to pass that the crappy four speed's gizzards will work, that'll be great news for patching up 63's.
Although this will be the last time I take this box apart. (Which I also said the last two times I pulled it apart lol)
I should post a coparison pic between the 63, and the 56's counterchafts. It's little wonder that the 56's break like glass.
Posted on: 2012/3/7 8:41
Forced Induction!
That's cheap for 63's compared to our prices. How many sheep is that?
Posted on: 2012/3/7 8:44
Anyone have a clunker 63a laying around for an L series? I can strip it and post over whatever you need. All I ask in return is Speights... Lots and lots of Speights...
Posted on: 2012/3/7 8:51
I do! Also I need my other other a rebuild.
Can I try a spighets!????
Posted on: 2012/3/7 8:59
I don't know what that is but sure, whatever floats your boat...
But if you want to try a speights, you'll have to go to Acland Cellars for me.
Posted on: 2012/3/7 9:15
How about $50 for a gearbox Mik, and I'll strip it and send the required parts to Bart.
Posted on: 2012/3/7 9:17
(1) 2 3 »
