h4 crystal headlights
ca any
1 tell me whai i have 2 do 2 hook these lights up please so i dont go blowing anything
Posted on: 2012/3/12 10:52
Re: h4 crystal headlights
From Melbourne, Australia
Are you talking just normal H4's or HID's? If just replacement h4 globes then just plug them in! Wiring up HID's takes a bit more work....
Posted on: 2012/3/12 11:20
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From Sydney.au
if you go to above 70watt bulbs for high beam you definitely want to upgrade your wiring, i fried the crap out of mine at first :)
i would recommend (same thing an auto elecy did for mine) adding in 2 relays, low beam and high beam, so that the wiring which comes from the interior of the car is used simply as a signal, then the hot 12V goes from the battery through the relays coil directly to the lights. also use a ~40amp breaker from the battery to the relays. the12volt.com always helps with stuff like this too. goodluck!
when i upgraded (learnt the hard way)
tech wiki lamp wiring
edit: if anyone has installed HID's some pics would be great. they are a bit too expensive to blow the $ now, but something i will do in the future..
Posted on: 2012/3/12 11:29
From Sydney
Hid lights are a plug and go thing.. Just plug the original plug into the kit and plug the ballast snd globe together mount the ballast then drive 10 minute job.
Posted on: 2012/3/12 11:33
evilsim is correct,
orange 1200/shoota... the original lights are sealed beam.... you cant even change the globes.... that's terrible advice
if you change from the original sealed beams you need to wire in a relay so that you can have a power source that does not go through the original loom/fuse box as it is not adequate
H4 is a great upgrade for all dattos
HIDs in driving lights are illegal (unless your car has sensors in the suspension to dip the lights when the angle of the car changes) and completely unnecessary! i use them in my spotlights in my rally car but even the rally scrutineers ensure we do not have them in the normal lights at each event. there is absolutely no need for HID light power in a road car
to wire in HIDs is easy but not plug in one end then plug in the other, you need to have your relays setup to power them and you need to make a mount to hold the ballast box, then often you need to modify the light/globe to suit also (particularly on spot lights)
Posted on: 2012/3/12 22:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney
^^^ my bad about the sealed beam part.. But every car I've had I've put hid light kits in head light, high beam and fog lights and have never ever had to add relays.. Just plug both ends in and off u go.. I've never had a problem... But hids in the datto in my opinion looked #OOPS# keep it old school bright yellow bulbs FTW!!
Posted on: 2012/3/12 23:09
1200rallycar wrote:
evilsim is correct,
Pull your head in 1200RC, put a bit more thought in before you slander someone's advice. The crystal headlights I believe he's talking about are a lowish wattage replacement globe and entire light housing that REPLACES the sealed beam unit.
It will plug straight in to the existing wiring with no modification necessary. How do I know? I have them in my ute.
As with any headlight, wiring in a relay is highly advisable especially in an older car.
Posted on: 2012/3/12 23:24
Current Fleet-
By miracle I didn't put relays in mine fir 2 years with h4 Bosch units and never fried the wiring but piggy installed some and glad he did ! Ive seen a few fried headlight looms
Posted on: 2012/3/12 23:29
why would you write "pull your head in"?
you said just plug new globes in... it is not possible
they will run the wiring hot if you don't have a relay, particularly on high beam and depending on how much corrosion and how good you connections are as to if it melts the wiring/starts a fire in your car
Posted on: 2012/3/13 2:10
1200 Coupe Rallycar
Easy boys, each to there own! I've done all above conversions, crystal with 55/60, 60/90, 60/100, hid bla bla, with the 55/60 they are not to bad you 'CAN' plug and play but... With any upgrade I recommend using relays as you get much better out come, and lessen the risk of melting looms!
In my past I have melted looms by doing this upgrade cos I never fitted relays but it also comes down to how long they are on for, how often, and the connections at each end, if corroded then it will make things alot worse!
I can try and find pics I have around of what happens ect if needed and can draw a simple drawing of wiring if needed
Posted on: 2012/3/13 2:52
Car free
