Ca18det injector upgrades??
I'm looking at buying a set of injectors for my ca18det, will be running nistune ecu just wondering what injectors I can go or even what other injectors or motors I can get from!
I no rb26dett 440cc injectors are straight swap is there any others? Do sr20det injectors fit? Please help! Ta nick of If u got some to sell let me no! Ta
Posted on: 2012/3/21 11:56
Car free
Re: Ca18det injector upgrades??
From Sydney, Australia
I'll have some 550cc rx7 ones I can sell once I get my car through rego check in the next 2 weeks.
I even have 2 spares someplace. I bought some 800cc ones I need to install. These 550s are oval plugs, would include plugs too. $250 delivered ($200 if i cant find the 2 spare). If you are interested I will move my ass. Mine are a different impedance, So like the ca18de, you don't need the dropping resistor.
Posted on: 2012/3/21 12:15
So do I need to take out the resistor bank?
Posted on: 2012/3/21 12:45
Car free
Yes you could hack it out, but I'd recommend that you find an unused connector thats the same as the dropping resistor block from the bits of the loom you haven't used. Use the connector to make a plug in bypass. That way you can switch back if needed in the future.
Posted on: 2012/3/22 7:11
I'm kinda after just bolt in ones as I have a keV rolie loom and just want to plug and play, been told gtr 440's will be enough for what I want, but thanks!
Posted on: 2012/3/22 7:27
Car free
For a totally plug and play solution, that's probably a good choice if you don't have a lot of wiring experience.
Posted on: 2012/3/22 9:17
More just easy
Posted on: 2012/3/22 12:44
Car free
From brisbane
I run GTR 440cc injectors on mine which has been dynoed at 182rwkw.
Be sure to replace the plugs as they will be hard and brittle by now. They are around $5-$8 each from injection shops.
Also, have a professional clean, flow test and replace the O rings before fitment. Cost will be $25-$40 per injector.
Posted on: 2012/3/22 21:19
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Yeah I got gtr injectors in my rb20det running 240kw and they keep up, I did that last time, clean and new seals! :)
Posted on: 2012/3/23 0:25
Car free
