« 1 ... 18 19 20 (21) 22 23 24 ... 52 »
Re: EVO 8 powered 1200 Ute
obviously your old man doesnt want it hanging around all year lol.... leave him to it more often
Posted on: 2012/3/29 13:28
From SA
Unfamilia I wish..... He's already had enough he reckons... Which I don't mind that means I get to learn but it is so good seeing progress like the last few days
Posted on: 2012/3/29 13:38
From Trinidad and tobago
Nice work buddy.
I also like your wheels alot.
Posted on: 2012/3/29 14:46
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Its getting IRS right? why not with all that tubing!!! :)
Posted on: 2012/3/30 5:14
From Melbourne, Australia
while your at this stage you should consider cutting back the footwell section behind the front tyres, this often needs clearancing to fit larger wheels (with a hammer if need be but the nice way is to cut and shut it back)
there was a good picture of this somewhere but i would have no idea how to find it now
the problem im reffering to is when turning - the tyre's outside edge will hit the footwell
Posted on: 2012/3/30 5:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From SA
It's not getting IRS now, going to do a 4 link set up with live rear axel, should still be really nice set up!!! I wanted to do Indapendent but was just a little to involved " hahaha " will def have a look at the foot weels... Still got a solid day tomorrow finishing off putting all this steel in...
Thanks
Posted on: 2012/3/30 7:32
From Nyngan, nsw Australia
should of picked the brains of Maddat about the IRS in there ute, not bad either
Posted on: 2012/3/30 10:53
living is good,.....
From SA
I have talked to Scott a little when I first started building the ute.. I Duno why I am keen to run a Live rear with 4 link now... Duno why !!! IRS would be cool tho..
Posted on: 2012/3/30 11:12
make interesting chat, its like looking behind at a hotrod with a chrome jag rear end while driving...looks mad as....
if i had sum detailed picks of Scott's set up i reckon id give it a crack..many things are made from drawing & pics, i know a couple years back in the ZOOM mag they were doing the IRS for utes... probably didn't have much call for them...maybe!!
personally with 4 links is the shock mounts hang low, i suppose depends on the position they sit, there's not a lot of room underneath, have you spoken to anyone else with this rear link!
cheers rod
Posted on: 2012/3/30 11:36
From SA
really when you break it down it's not that much work but have just decided to head down a different path I guess... Would def be good to get a look under there ute and in the tray... All good tho !!!
Only to Ray McDonald the fella makes the kits..., just all a big learning curve... Not going to rule it out just yet...
Posted on: 2012/3/30 11:56
