CA18DE AUTO 1200 UTE
From Southern Highlands, NSW
Hi Everyone, just asking has anyone done what i want to do?? I have a ca18de with an auto box. What does everyone think? Is it going to be a big pain? how will i go about running a speedo, i know the ecu need a signal so that rules out a mechnical speedo, Yes??? Also i started connecting the loom, does the gearbox plug into a controller before the ecu, i ask because it semse im missing connectors?
Posted on: 2012/4/1 7:20
Re: CA18DE AUTO 1200 UTE
Posted on: 2012/4/1 8:11
Car free
From MOOROODUC. Victoria
Thanks Nick for remembering my thread.
Hi Hugh (looked up your profile)
The Auto needs two ECU's - one for the engine and one for the Auto (for the auto get a number 1)
as you have probably seen in my thread i took the whole loom and installed it in place of the 1200 loom
I should have got a half cut and used everything from one car, but the nature of collecting things meant that i picked up stuff (and some annoying problems) along the way
As a summary I replaced
Motor (CA18)
Gearbox (sourced separately but from a Silvia)
Loom - another s13 Silvia
Cluster Gauges (yet another S13 and ended up with two)
windscreen wiper motor
Fuel tank - needed the electric pump so went the whole hog on that (although you could modify the UTE tank and fit a modified pump)
... I actually had no intention of replacing some of that stuff - one thing led to another
Two tips.
Use a really big new transmission tunnel - not even the standard Auto tunnel is fat enough (on drivers side)
Go closer to the fire wall than I did - my setup is too far forward and does not leave much room for the thermo fan etc
If you're in Melbourne and want to see for yourself .... PM me
Posted on: 2012/4/1 8:56
Posted on: 2012/4/1 9:21
Car free
