CA18DET carbon canister install
From Melbourne, Australia
looking for a simple explanation of where the hoses go from the carbon canisted, the S13 manual doesnt include that fat hose from the bottom of the canister... so thats confusing!
there is vac line written for top of diaphram
purge on bottom of diaphram i think? what is that?
and the other on top says fuel tank which i guess is the obvious one
can someone give me a quick explanation please?
Posted on: 2012/4/8 9:42
Edited by 1200rallycar on 2012/4/9 11:08:27
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: CA18DET carbon canoster install
found some pictures, either side of diaphram go to throttle body (hose sizes give away which goes where) other hose fitting from top of can goes to fuel tank.
only question remains is where does the 13mm odd hose go from the bottom of the can?
Posted on: 2012/4/8 11:13
1200 Coupe Rallycar
Use it to collect all the oil out the breathers
Posted on: 2012/4/8 11:34
From Sydney
Atmosphere.
Posted on: 2012/4/8 12:03
From MOOROODUC. Victoria
Exactly .... the atmosphere ... mine just goes to a hole and then out into the air
If you're at all still confused just go down the Nissan isle at any wreckers... they're pretty common
Posted on: 2012/4/8 12:24
Have you decided where your going to mount it? I saw what Tommo did with his but I'm interested to get some other ideas.
Posted on: 2012/4/8 14:44
between drivers headlight and intercooler looks possible for me, tempted to put it there because its easy,
under guard is super neat but i think its likely to be a temporary install so im not going to too much trouble
Posted on: 2012/4/9 0:09
1200 Coupe Rallycar
installed today, not plumbed in yet,
does the vent to atmo need an air filter? or is that only for purging out?
this one is from a CA18DE, do i need anything extra becuase im using on CA18DET.... i.e. will boost be a problem?
Posted on: 2012/4/9 11:21
1200 Coupe Rallycar
didn't think it was sposed to vent to the atmosphere, sposed to be hooked up to the throttle body i thought
Posted on: 2012/4/9 11:31
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
dunno now... i'm reffering to the 13mm hose from the bottom of the canister, earlier posts recommend it goe to atmo,
the only reference i have found elsewhere says it goes to the chassis rail.... not sure what that means....
Posted on: 2012/4/9 11:36
1200 Coupe Rallycar
