Wanted Dead Or Alive: 7/8 Master cylinder
From Melbourne, Australia
gday, i am need of a 7/8 master for my 1200, i will be sleeving it so working condition not important
anyone have one going cheap cheap, i could buy new for $120 but to buy new and sleeve it is wasteful
or even if someone can recommend a car that is likely to be in pick a part (wreckers) that i could take one from which will bot up to 1200?
[edit] to remove excessive use of caps lock on tiltle
Posted on: 2012/4/5 10:13
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Wanted Dead Or Alive: 7/8 Master cylinder
From Perth
Any 240 or 260 series
Why sleeve if you can buy new ?
Posted on: 2012/4/5 12:01
no luck at wreckers, bump, anyone got an old one?
i want to get it sleeved down to 11/16 or 3/4, need it look like 7/8ths from the outside though
Posted on: 2012/4/8 6:03
1200 Coupe Rallycar
From MOOROODUC. Victoria
Try this guy
http://www.zshop.net.au/
He's in Glen Iris
Posted on: 2012/4/8 7:58
From Perth
I'll get you a price on a new one on Tues if you remind me
And I assume you have thought about this sleeving down thing... you'll need the identical pistons of the right length in the smaller size
Posted on: 2012/4/8 12:46
i hadn't thought about it much actually, i spoke to a brake place and he said he knew a place to do it, but im better off finding an old one to bring in and have it done
i had every bloody size but 7/8 or 1inch under my house
Posted on: 2012/4/8 13:26
1200 Coupe Rallycar
From Southern Highlands, NSW
is it the booster one off 120y? if so i have one thst works. If you get me a picture of what you need i will look in my big box of goodies. :)
Posted on: 2012/4/8 23:19
I've got 2 x brake cylinders, unknown condition, 11/16 (single) and 3/4 (dual-missing caps and shaft) - $10 ea
if interested.
Posted on: 2012/4/11 8:21
i just found i need a 180b one, 7/8ths size, correct mounting and look like the original
getting to the stage where i think ill just buy new now, unless a local as one?
Posted on: 2012/4/11 9:07
1200 Coupe Rallycar
