« 1 (2) 3 »
Re: More Power?
Quite a regular
From SA
extractors, 2 inch exhaust, 32/36 weber carby and change all the oils! is the way to start, its cheap and affective!! then get on upgrading your spark such electric dizzy a good set of leads and plugs... and if you really want to build a high powered A12, look at buying a second engine and go all out on it over time..
i have an A12 with :
Bore: 74.5mm
Stroke: 73mm
Pistons: Teikin Flat-tops, Floating Pin, Fly-cuts
Compression Ratio: 9:1 (tame)
Camshaft: 224A Racing Cam
Lightweight mushroom lifters
Lightweight pushrods
Knife-edged & lightened crankshaft
Lightened undersized crank pulley
Balanced from pulley to clutch PP
Ignition:
Scorcher Distributor (electronic)
Bosh GT40 Coil Eagle
10mm ignition leads
Head:
H75 Oval Port Head (excellent condition) Mild port, decked.
Intake Ports: 40mm x 30mm Exhaust Ports
Valve Sizes: Intake 37mm Exhaust: 30mm (stock)
Double Valve Springs
Aluminium lightweight retainers
Induction:
Twin 40 PHH Mikuni Carbs- 30mm Chokes
Medium Ram Tubes
Bprojects big port manifold & linkages
Uni-filter Air-filter Socks
Clutch:
Ultralight & perforated flywheel
Brass button clutch
Posted on: 2012/4/16 5:56
Re: More Power?
Not too shy to talk
From Fallon,NV
Well Id like to make the car a drag racer but id also like it to still be street drivable. I don't want to put a bigger motor in it, but I very much thank you all for the advice and tips. hopefully I can let you all know about my progress.
Posted on: 2012/4/18 6:16
Re: More Power?
From Sydney
African kid what power are you making atw??
Posted on: 2012/4/18 8:00
Re: More Power?
From Near Bundaberg QLD
First thing you really must do is save up for an electronic points conversion kit (pertronix, crane cams, both are good) will cost you about 100-120 bucks but is worth every cent. Comes with all instructions, all you need is a screwdriver and an 8mm spanner and 15mins of spare time. Make sure you have new plug leads, dizzy cap, and rotor button when you do it. Save up another 35 bucks and get a Bosch HEC715 high output epoxy filled coil off ebay to replace the old oil filled coil and ballast resistor. Make sure you join the wires together where the ballast resistor used to plug into.
I know it might be boring and takes a bit of time, but read thru all of the info in the tech wiki religiously, it has all the good information which has appeared on this forum, it has saved me (and 100's of others) tons of times in the past.
Posted on: 2012/4/18 10:10
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Re: More Power?
From south coast nsw
buy another car that already goes fast is the best option you will find out 5 years later after u add the bills up.or change the camshaft and go from there.i learnt there no point bolting on mad stuff with a stock cam,if only the A series was ohc and easier to change
Posted on: 2012/4/18 14:25
Re: More Power?
Greeny, that's why the l is the perfect choice. Ohc, chain driven, power up and affordable.
Not rocker ship fast but fun
Posted on: 2012/4/18 14:44
Re: More Power?
From Malaysia
not to mention 5 speed is much affordable for an L
Posted on: 2012/4/18 17:56
Re: More Power?
I'd look into the vehicle modification rules for your local area/Arizona before thinking about engine conversions KDSB110.
How hard are L-series engines to come by over there?
Posted on: 2012/4/19 9:39
Re: More Power?
yeah im not a hater of the l series thats for sure mik, especialy after seeing that orange 1600 at datnats last year,after driving a b210 for a while i reckon L series 210 would be better then 1200.
Posted on: 2012/4/19 11:16
Re: More Power?
Lseries b210 should have been stock for sure
Posted on: 2012/4/19 11:36
« 1 (2) 3 »
