(1) 2 3 »
Advice please- making heat shield maybe
Ok looking at making a heat shield between intake manifold and extractors, to deflect heat away from intake runners.
So info I got was use 0.4 mm alloy sheet
Can I just bolt to exhaust bolts with brackets?
Silicon pipe on intake has temp range to 190deg c and I'm sure heat from extractors may be more and silicon bout 5cm from extractors
Posted on: 2012/5/1 11:14
Re: Advice please- making heat shield maybe
Sillycon hey no welding? Id be inclined to use a piece of cement board with alloy plate on the heat side :)
or raid neighbours old Hardi cement board from his bungalow should have enough asbestos.
Posted on: 2012/5/1 11:21
Yeah think so. Braced from under from plenum to flange so if can add sheild from exhaust bolts to some part of brace or down wards leaving air only around silicone pipes
Posted on: 2012/5/1 11:37
you could put some of that heat barrier sheet on the bottom side of the alloy?? would look the part
Posted on: 2012/5/1 11:41
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Melbourne, Australia
Get a bit more 1mm sheet metal from our mate in Coburg then stick some bitumen heat shielding straight to it.
Or, go to the wreckers in Broady and climb under an EA-EL Falcon. They used a lot of really good rippled heat shielding around the exhaust tunnel under the car.
The most preferable way is wait till I've got a bit of practice aluminium TIG weldinmg done and then I'll weld your runners for you!!
Posted on: 2012/5/1 11:46
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Your can plug weld me any day shoota.
Yeah tiging is an option long term but I don't know how it's going to run with longer runners so silicon seems logical first off. See how it comes back.
Lethal what's this sheet stuff? Or broadly stuff seems will be fine too. Just need to work out how to attach.
Posted on: 2012/5/1 12:05
Where in tunnel up front or in the rear you know I like in the rear.
Looks like a trip to pick a part on cards, falcon guys love the stock heat shields..... Dime a dozen so need to find one and then mod to fit . Tin snips drill vice clamps and bending needed . Shoota you need one on your ute
Posted on: 2012/5/1 12:25
i have a ca18de one i could rescue from my bin
Posted on: 2012/5/1 12:31
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Rescue for me and see if fits ...... Save me some $$$$ lol again
Posted on: 2012/5/1 12:42
(1) 2 3 »
