chasing webber info
From yeppoon qld
im trying to find a set of webbers for my ute,but just trying to find info on which size and type to put in.any comments would be great
Posted on: 2004/3/26 12:18
Re: chasing webber info
From Melbourne, Australia
what motor????
Posted on: 2004/3/26 12:26
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From yeppoon qld
its for my work ute a12 motor 1981 model
Posted on: 2004/3/26 12:54
size wont matter, its the size of the "chokes" or venturis inside them that matters, im no expert but you probably need something with 32 or 34mm chokes, changing them is expensive so try to find out what size you need a buy a set of webers with that size choke installed, other than that stay away from "42" webers as the air delivery is not suited to small motors, 40 or 45s will be fine with the right sze choke
Posted on: 2004/3/26 12:58
1200 Coupe Rallycar
From Brisbane
go 40s mate on A12. i have 40s on my A14 (1434cc) with 32mm chokes.
you may even need smaller chokes. all depends on what Cam you run and what motor and head mods you have done as well. 40s on a stock A12 would run poor. i have seen 40s on a stock A15 run okay.
A a12 with head work and cam would suit nicely with a set of webers
Posted on: 2004/3/26 13:21
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From yeppoon qld
ok sweet thanx for that info .now i just have to find some
Posted on: 2004/3/26 13:34
oh yeah, dellortos are practically identical, use the same parts and are just as good, usually cheapper too
Posted on: 2004/3/26 13:41
1200 Coupe Rallycar
