blowing fuses
I bought aftermarket lights off ebay that take h4 globes and when they are on I can actually smell the fuse getting hot while im driving until it eventually melts.
Is there an easy fix?
All my wires are stock, no relays or anything.
Ive done a search and everything keeps coming up with mixed results.
Posted on: 2012/5/22 9:47
Re: blowing fuses
Need relays- also its more likely the wire sheaths melting or the actual fuse box
Get onto it ASAP.
Might also benefit taking the fuse box out and cleaning the connectôrs
From the rear.
Make sure you label where the wires go into the box too.
Posted on: 2012/5/22 10:27
Re: blowing fuses
From Perth WA AUS
Just like he said ^^^^, unless there is a short circuit in the wiring but that should blow the fuse straight away.
Posted on: 2012/5/22 11:31
Datsun 1200 2Dr sedan.
Re: blowing fuses
What wattage are the globes? Your standard circuit is not designed to take more than 50/55 globes. If you have fitted higher wattage globes you can kiss your fusebox goodbye. I hate to say it, but as Mik said, Relays are the answer.
Posted on: 2012/5/22 11:44
Re: blowing fuses
Don where's the love???? Your not my wife- show me some loving....
I learnt this lesson before it happened. Luckily. I used 60:90 globes and was very lucky.
Posted on: 2012/5/22 13:04
Re: blowing fuses
So if i put relays in can I use the higher watt globes?
If I just change the globes to 50/55 will it be ok without relays?
Posted on: 2012/5/22 14:02
Re: blowing fuses
From Albany, Perth Australia
if this helps, wouldnt be more then about an hours worth of work
http://www.humanspeakers.com/audi/headlight-simple.htm
Posted on: 2012/5/22 14:20
1200 Smerf Mobile
Re: blowing fuses
H4s are considerably brighter because they use considerably more current!
It will overload the existing wires. Relays won't fix the problem, you need larger wires with the relays!
Posted on: 2012/5/22 19:32
Re: blowing fuses
I thought that would be obvious dd, sorry should have mentioned that
Posted on: 2012/5/23 1:05
Re: blowing fuses
Here's some more information on using H4s in a Datsun 1200.
Headlight Wiring
* Relay
** Harness Kit
** DIY
It has pictures and such
Posted on: 2012/5/23 2:07
