Diffs
From Goulburn NSW
Hi guys im thinking about my rear end conversion and what diff i should be fitting.Are borgies tough enough for 350hp if i go full house,also thinking 9"or is that overkill.Any opinions would be appreciated.
Posted on: 2012/5/24 2:32
Re: Diffs
8 inch Ford are easier to source, LSDs easily available and has an affordable aftermarket Currie Ent. Alloy carrier available to cut the weight down unlike Hilux and BW diffs which are heavy and contradict the iconic rep of Datsuns being Light and nimble.
Check out my thread "what a lovely rear end"
http://datsun1200.com/modules/newbb/v ... id=406911#forumpost406911
Posted on: 2012/5/24 3:05
Re: Diffs
350 hp below 5000 RPM, go with the 9"
Above 5000 RPM a smaller, lighter diff will work, like one of the larger BW units.
Posted on: 2012/5/24 3:06
Re: Diffs
From Trinidad and tobago
hey Mcdat Just from what i kno of H190 7.49 ~285 lb. ft,
A 400HP engine with 275 lb ft torque could get by with a much smaller diff than a blown 400HP engine with 500 lb ft torque.
Posted on: 2012/5/24 3:07
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Diffs
From Melbourne, Australia
Borg Warner for sure.
They're very plentiful, LSD's readily available and lot's of off the shelf centres and ratios around.
Yes they're heavy but it will take a lot more than 350HP to wreck one.
Posted on: 2012/5/24 3:08
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Re: Diffs
From Goulburn NSW
Thanks guys much appreciated.
Posted on: 2012/5/24 3:17
Re: Diffs
From Melbourne,Australia
Ive got a borgie 78 in mine never had a problem with around 300hp. Plus there are plenty of them in 8-9 sec vl's falcons ect so will be plenty strong enough
Posted on: 2012/5/24 5:09
Re: Diffs
From Goulburn NSW
Hi guys is it illegal to 3/4 clip a ute,and the next ? is will the engineers pass it.
Posted on: 2012/5/24 6:49
