« 1 ... 23 24 25 (26) 27 28 29 ... 42 »
Re: 1200RallyCar's - CA18DET 1200 coupe
From Melbourne, Australia
yes but the idea of the 190 is it won't break, otherwise i'd put the 165 back in and keep a healthy supply of spare components
i have discs already and a topgear centre (not installed) so i'm happy to keep this diff
and hopefully not needing to move mounts will mean shorten is not too expensive
Posted on: 2012/5/29 13:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Armidale N.S.W
Love those wheels they set it off nicely.
Posted on: 2012/5/29 14:31
73 1200 wagon SOLD
been mucking around with the air intake, just because using the silvia hose it sat on a funny angle and the hose had a kink
just used an exhaust offcut from exhaust place, got him to weld a steel hose barb from bearing wholesalers on and flare the ends to 60mm
then used some angle aluminium to make a bracket that reached around the water squirter bag,
two 90 degree silicone hoses from UK (cause they actually stock 60mm) and i'm waiting on hose clamps that supafatto has for me
Posted on: 2012/6/1 14:19
1200 Coupe Rallycar
Here they are
Posted on: 2012/6/1 23:11
Car free
-Finished off the air filter setup with clamps, thanks supafatto
-Wired thermo fan to control by temp sensor
-Made a shortened cig lighter which doubles as a peep hole to check the cltch resevoir level
-Made a fake choke cable
-Rewired the power to coils around the back of the stock tacho, hopefully that will work (was able to fit 25amp wire past back of tacho through the standard fitting, which is heaps over the 15amp fuse)
So i will have a complete stock looking dash after all this (with everything working) only change being a modern Stereo head unit, which is the look i wanted
Posted on: 2012/6/3 8:00
1200 Coupe Rallycar
Nice weekends work from both sFatto and yourself!
Reason for having to up the amps ? Stock dash all working is better than they come out of the factory lol all working I mean.
What's the vac line off intake pipe going to?
Posted on: 2012/6/3 8:50
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
yeah pretty happy with the weeks progress
went with 25amp wire as i was extending the length of the wire, i wanted to upgrade to a larger wire, that way i wouldn't be increasing the resistance significantly over the stock wiring
intake t goes to catch can which is fed by rocker cover
Posted on: 2012/6/3 9:07
1200 Coupe Rallycar
Yeah right I didn't know that's what some catch cans require.
Piece by piece it's getting there mate well done
Posted on: 2012/6/3 10:13
footy was boring so went back to shed...
started install of 120fly fiberglass kick panels, had em for years and years
good stuff, bugger to cut the speaker hole with just an angle grinder though. still have to do passenger side
Posted on: 2012/6/3 12:13
1200 Coupe Rallycar
Oops
Posted on: 2012/6/3 13:47
Car free
