Engine Stalling when parked
From Brisbane
I notice that when Im parked and left my engine running it stalls after between 5-10 mins i dont know whats going on...
is it supposed to do that?
Posted on: 2004/3/30 0:15
Re: Engine Stalling when parked
From Sydney, Australia
Sounds like the needle and seat in the carby is buggered. The float level gets too high and it floods. Causing horribly rich mixture making it stall. Does it make "lumpy cam" noises before it stalls, or simply run out of fuel? Maybe the fuel pump is buggered it it just quietly dies.
Chris
Posted on: 2004/3/30 3:47
From Brisbane
it doesnt make any weird noise before it stalls just all of a sudden its quite! engine stopped running
I replaced the fuel pump before and that was working fine and confirmed by my mechanic THAT TIME
Posted on: 2004/3/30 3:54
If it only happens at idle, then it can only be fuel, checked your fuel filters? That could also be that. And if you say the pump is ok, then the filters it is. Normally though, this would also mean problems under all engine loads.
Chris
Posted on: 2004/3/30 6:40
From Auckland N.Z
Mabe Datsun were smart and its a deliberate function that stops you cooking your motor by leaving it idle for 10 mins.
Posted on: 2004/3/30 7:04
I doubt if Datsun tested the engine just idling for 10 minutes ... I wouldn't expect mine to idle for long periods of time.
If the engine is cold, yeah it does that.
If the engine is warm, it's not "supposed" to die, but it might due to engine-compartment temperatures, fuel-recovery emissions system or other reasons.
Posted on: 2004/3/30 8:09
From Brisbane
I just changed my fuel filter last week
Oh well I guess I got those unique "OPTIONS" you can get for your car automatic engine shutdown - cool!
Posted on: 2004/3/30 22:35
From Castro Valley,CA USA
I'm surprised that "feature" isn't a smog requirment on all the cars here in California. Sounds like it does a good job of reducing idle emissions.
Posted on: 2004/3/31 1:30
Quite a regular
From North Carolina-USA
One problem I had with my car was that when I stoped and had it out of gear it stalled, which was due to the clutch engaging. Had several problems with the carb and such too.
Posted on: 2004/3/31 5:18
From Brisbane
I think someone told me that my torque converter is not disengaging properly when starting thats why it makes a loud pitchy cranking like noise when starting.
Posted on: 2004/3/31 6:13
