Browsing this Thread:   3 Anonymous Users
How To: Moar Castor
Datsun 1200 came with very antiquated Wheel alignment settings. They didn't drive very straight even when new.
A little more caster will fix that!
Cut the Tension Rod rubber bushings in half, and shorten the metal spacer and put it back together. It will pull the wheels forward just enough to track well, with no wandering. Even with hands off the wheel it will drive straight.
1. Park on a level surface and measure the toe-in. Mine was right on spec, 3mm closer at front of tire compared to rear of tire (or 4mm measured from tread centerline, but as you can see I measured closer to the hub)
I used the long stick to go clear across the car and measured front tape to rear tape.
2. Remove the Tension Rod (castor rod). Undo the front nut, then the two bolts on the LCA, then pull it out.
3. Cut rubber bushings in half. Cut the metal spacer tube down from 42mm to 18mm. Stock used bushings were 21mm thick.
4. Insert back through the Tension Rod Bracket and tighten bolts to specification. Remember this is suspension parts, you life depends on them, so do not weaken the fasteners by overtightening. 5.5 to 6.5 kg-m (40 to 47 ft-lb)
5. Re-measure the Toe-in, and if out of spec (4-6mm) then evenly rotate the side-rod ends until Toe-in is correct.
Enjoy driving.
* Before: two hands gripping the steering wheel, making frequent steering adjustments on straight roads
* After: two hands lightly holding the steering wheel, making occasional steering adjustment
Posted on: 2012/6/12 8:15
Edited by ddgonzal on 2012/6/12 8:30:18
Edited by ddgonzal on 2012/6/12 8:31:24
Re: How To: Moar Castor
From mandurah
i did this and it works a treat ,stops rubbing on the firewall aswell when running wide wheels
Posted on: 2012/6/12 9:05
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Plus I didn't notice heavier steering, but I only did this mod today. Theoretically more caster = heavier steering, but Datsun 1200 has extremely light steering to begin with (until you fit the monster wide tyres).
Posted on: 2012/6/12 9:10
From Malaysia
can i do this for my 1600? exactly same problem, the car wanders if i take my hands off the steering wheels.
Posted on: 2012/6/13 0:28
Yes, but details may vary.
It can also be caused by incorrect alignment, worn out bushiings or by excessive lowering.
Posted on: 2012/6/13 1:43
From Malaysia
no, yes and yes hahahaha. worn bushings, freeplay steering box and excessive lowering contributes.
Posted on: 2012/6/13 1:57
hi guys. does datsun B310 castor bar is hollow? rethreading is not adviceable..?
Posted on: 2014/11/18 17:33
No need to re-thread the castor bars. Just cut the bushing in two.
Posted on: 2014/11/27 7:44
ok.. will try that....
Posted on: 2014/12/1 14:35
From Sydney Australia
C110 otherwise known as 240K Castor rod rubbers fit straight in and are much more solid giving a vast improvement in control under hard braking as well when doing this mod, Urethane are often too hard and end up breaking stuff if not careful hence why I use rubber just better rubbers even with stock Castor let alone "Moar" (more) Castor
Posted on: 2015/1/2 11:40
