« 1 (2) 3 4 5 6 »
Re: Which would be easier to install rotary or CA18DET
From sydney
The difference is the way the RTA treats each engine, whilst you could do a 2 litre conversion you couldn't do a turbo 2 litre but you could do a turbo 1.8 litre, they treat a 13B as a 2.6 litre so no go turbo or naturally aspirated.
Posted on: 2012/6/12 14:34
From Goldcoast
Oh well thats a bit sucky :( I take it a 12a rotary would be ok though? not sure if a 12a would have enough power weighed up against the work & cash that has to go into the conversion.
Posted on: 2012/6/13 1:44
12A makes up to 700 HP, doesn't it?
Posted on: 2012/6/13 1:57
From Narellan,Sydney
12a will still make way more power then your after
Posted on: 2012/6/13 3:42
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From south coast nsw
have you thought about 4age or 4agte, small reliable cheap and less hacking of the car.
Posted on: 2012/6/13 4:05
From sydney
A hot A series is a great engine with heaps of power, and will bolt straight in.
Posted on: 2012/6/13 4:11
From Goldcoast
Hi What do you mean by a hot A series, are you refering to the Rotary 12A?
Posted on: 2012/6/13 4:30
From Freo
vote 1 for Sidedraught.. Hotty A series for the win...
Posted on: 2012/6/13 4:34
A15 PSI Project Motor
'72 CB750k,
"Hot A-series" means Datsun A-series. For example, 170kw out of an A12, only $1800.
And the expense of swapping it in ...
Posted on: 2012/6/13 4:37
From Goldcoast
Ok Im a bit confused because as far as I know I have a A12 in my ute already?
Posted on: 2012/6/13 4:43
« 1 (2) 3 4 5 6 »
