Engine removal tips/Paint
Hey all, The little A12 is coming out tomorrow so I can spray the bay, I want a fairly good job, but i don't want to remove wiring harness, brake booster, or brake lines, everything else will be out.
Also, looking at painting the engine and parts when it is out, thinking about using a pedestal wire wheel on things like, alternator regulator, wiper motor and timing cover, then just doing a clear coat over the top so it doesn't rust/corrode, painting block and rocker cover as close as i can to stock, also the air filter.
Not sure if i should remove manifolds to paint, or leave them on and mask/news paper.
Has anyone ever done something similar to this before and have tips/tricks ideas, that they would like to share?
Any positive input is greatly appreciated.
Thanks, Zak
jpg  IMG_0852.JPG (179.23 KB)
16411_4fdc40ce9e982.jpg 1200X900 px
Posted on: 2012/6/16 9:16
Re: Engine removal tips/Paint
From south australia
Use alfoil to mask hard to mask stuff like electrical wires and cables. It's a lot easier to work with than paper in these areas. You will get a better job removing manifolds. But keep in mind you might need to replace gaskets
Posted on: 2012/6/17 0:01
From Brisbane, Australia
You might want to remove the oil pressure sensor as it is easily damaged when removing the engine.
Take you time with it, Good luck.
Posted on: 2012/6/17 1:02
From Goldcoast
Love the alfoil idea, im in the same situation zakdat so I will be following this thread closely :)
Posted on: 2012/6/17 2:31
