Browsing this Thread:   3 Anonymous Users
« 1 (2) 3 4 5 ... 30 »
Re: Finally start my 1200 sedan build thread
From Narellan,Sydney
I found a donor that was in pretty good condition.will be more pics wen I get home
Posted on: 2012/6/13 3:39
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Bit more info on my build :)
Started about 3years ago then starting getting stripped got media blasted and away it welded up rear end the made holes for my own custom tail lights.mini rubbed and welded bigger tunnel in.made up my own stainless steel dash which houses 6 autometer gauge.
Car was straighter up rust removed smoothed all seems in engine bay and shaved door locks then hi filled.sat in hi fill for a few months then blocked back and sprayed in a custom violet pearl mix all in spies heckor.(car is actually purple photos don't do it justice)
Made up cross member and engine mounts and dropped in the new power plant a Cosmo 13b twin turbo motor converted to big single turbo to be built and bridgeported by sdr Motorsport in the next few months.aiming for 450-500hp on race fuel :)
Made up my own mirror finish stainless grill that deffenetly is a 1off.every single bolt that isn't hi tensile has been mirror polished finish and is all stainless
Waiting on my show wheels to arrive from America ATM then shortening and fitting the diff then make up my 4 link.will then will be off to xtrim to install rest of the interior in custom trim
Aim was to build something different to most datsuns and I think I've done that
All work has been done by myself.Will be more pics as I get the time :)
Posted on: 2012/6/18 12:11
Posted on: 2012/6/18 12:23
From Canberra
What size wheels have you ordered put of interest? Good to see another copping the rotor treatment!
Posted on: 2012/6/18 12:24
YLD.18L
17x6" up front and 17x10" rears
Posted on: 2012/6/18 12:28
From Goulburn NSW
Hey how are u?did u do anything with the chassie rails when u mini tubbed it?Im aiming to tubb my ute as much as possible,the fatter the better.It will look sick with 10"s under the back.
Posted on: 2012/6/19 9:31
Yeah mate the rails need to be cut at the front and back of the wheel arch
Posted on: 2012/6/19 10:14
From Goulburn NSW
Did u manage to get that engineered.
Posted on: 2012/6/19 10:36
Won't be getting engineerd mate they don't allow the 13b so not going to bother with it
Posted on: 2012/6/19 10:50
From Goulburn NSW
Cool i was thinking about that,is it going to be a powercruise car.
Posted on: 2012/6/19 10:54
