Installing handbrake cable
Quite a regular
Hey guys,
I'm changing the handbrake cable on my ute but I am a bit stumped on how you attach the new cable to the clevis on the drum brake? Is it a simple method or do you have to solder the cable end back on after putting the cable through? Or was the new cable I bought meant to come with a new clevis attached?
cheers
Posted on: 2012/6/22 3:17
Re: Installing handbrake cable
Quite a regular
Some pictures to make it easier!
Posted on: 2012/6/22 4:03
From Sydney NSW
on the front face of the clevis (where your thumb is) there should be a bigger hole to allow the end of the cable to slide through
you could just drill out a hole big enough on that side to fit the cable through
Posted on: 2012/6/22 4:36
1200 Ute
From MOOROODUC. Victoria
I drilled a hole in mine to allow the slug in the side just above your thumb
Posted on: 2012/6/22 4:46
Quite a regular
Yeah I ended up doing that as I checked the other side and there was a larger hole but missing on the passenger side for some reason.
Has anyone else used one of the handbrake cables off ebay? The cables that go to the other wheel are too short for a ute not sure if its different on the sedan/coupe.
Posted on: 2012/6/22 6:33
Quite a regular
Actually I cant use any of the cable as it doesn't reach the cabin either
Posted on: 2012/6/22 7:47
From Sydney NSW
Yeah i think the ute cable is longer than the others
Posted on: 2012/6/22 9:25
1200 Ute
