CA18de FROM A Exa into a 1200 ute?
From Goldcoast
Hi guys I am in need of a cheap run about to get me through a few months and a Nissan Exa has come up for sale in great condition and at a good price.
Another bonus is that it comes standard with the CA18DE which was a engine that I was considering for the ute, which means when I have finished with the Exa I would be left with a engine for mi ute.
Now this is where my mechanical knowledge shows the Exa is a FWD and my 1200 ute is a rear wheel drive is that going to be a problem atall?
Thanks
Andy
Posted on: 2012/6/23 5:51
Re: CA18de FROM A Exa into a 1200 ute?
From South east vic
Yes if it's a exa fwd ca18 bolt spacing for gearbox fitting is wrong, you need to find out if it has a s13 rwd motor fitted or not!
Posted on: 2012/6/23 6:44
1200 coupe under construction
From Goldcoast
Hey its a standard Nissan Exa FWD.
Posted on: 2012/6/23 8:24
From South east vic
No good bud you would need to adapt a gearbox to it!
Posted on: 2012/6/23 8:53
From Goldcoast
No worries thats good to know, thanks for your help
Posted on: 2012/6/23 9:08
From WTB 4 speed 60a & vb10 shell
All CA no matter what have the same bolt on pattern for RWD or FWD boxes the only thing that changes is FWD have no main bearing ladder brace and different semi winged sump but all good considering the block is so rigidly webbed much more than an A15 and only 1.6mm more stroke. Nissans Cosworth version is like Toyotas 4age but with more capacity and hydraulic lifters like the Suzuki gti g13b they never give you issues and cheap as chips.
Posted on: 2012/6/24 12:35
During times of universal deceit, telling the truth becomes a revolutionary act, Big Brother is watching you - George Orwell
From Seattle, WA
You mean all CA18 have the same transmission bolt-pattern. Because other CAs have a different bolt pattern.
So CA18 from a pulsar is good. Yes, you need a RWD gearbox, but even a CA18 from a Silvia/180SX will also need a RWD gearbox.
Posted on: 2012/6/24 22:13
B110 sedan: L series and 4 speeds, the way they were
All CA blocks have the same rear bolt pattern to suit fwd or rwd no matter the year or model all interchangeable. There is even a diesel model which very much interests me.
Posted on: 2012/6/25 1:00
From Seattle, WA
They say CA16 differs from CA18/CA20 bolt pattern, but I haven't been able to verify.
Is the CD17 diesel related to the CA?
Posted on: 2012/6/25 2:26
