« 1 (2)
Re: mira front bar
From Sydney
I've got a fiberglass one fits perfectly I no longer want it make an offer
Posted on: 2012/6/23 9:51
Re: mira front bar
Any ideas how to keep the middle grille fellas?
Posted on: 2012/6/24 3:41
Re: mira front bar
Seems everybody removes the mira lower grille when they fit it to a 1200.
But maybe you could notch the grille at the corners so it will fit in between the 1200 indicator lamps.
Posted on: 2012/6/24 4:06
Re: mira front bar
Cheers DD. Attempting to do exactly that. The problem I am finding is that the grille is really deep. Will definitely need a little more adjustment to sit tight against the ute under the standard front bumper.
Posted on: 2012/6/25 11:25
Re: mira front bar
From Sydney
I stopped cutting ages ago and put the bar aside when I got stuck with the grill aswell. I have thought hard about cutting the grill completely out and adapt something else into it. Now that the topic had been brought up, I'll have a play and see if I can cut and shut a plastic 1200 grill into the Mira bar. It's just an idea at this stage. Just be careful with the mira bar, you don't want to take too much off it.
Posted on: 2012/6/25 15:00
Re: mira front bar
That's a really cool idea, let us know how you go with it!
Posted on: 2012/6/26 12:04
Re: mira front bar
I want to try and make my Mira bar look like this, but not that extra bottom bit.
Posted on: 2012/6/28 13:05
Re: mira front bar
From Sydney, Australia
I tried keeping the grille in the middle, but was too hard so just chopped it out. Looks fine if you put something else in there to fill the gap.
Posted on: 2012/6/28 22:25
B110 sedan
« 1 (2)
