« 1 (2) 3 4 5 »
Re: EOI datto custom parts
From Sydney
I'm keen for the lca If u make them to fit stanza struts
Posted on: 2012/6/24 8:32
VERY interested in LCA (not billet) and castor/camber strut tops that bolt in, and preferrably use the original rubber isolator
PS - what modelling software you using for that?
Posted on: 2012/6/25 2:33
From Adelaide
Posted on: 2012/6/25 4:13
If life were easy it'd be boring
maddat.com.au
1200 ute SR20DET (Sold)
200BSSS (racecar project)
P410 Bluebird (original)
Merc. Vito Van (tow Car)
From mandurah
ide be keen on ,LCAs(moddoed stock ones) ,camber tops ,and lockable hydro hand brake ,all depending on price
Posted on: 2012/6/25 4:35
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From gold coast aus
ALL OF THE ABOVE
Posted on: 2012/6/25 5:42
From radelaide
i use a few different programs mostly auto cad and mastercam for machine programing
Posted on: 2012/6/25 9:58
HY_FLO MOTORSPORT - designing a new wave in motorsport
hy.flo912@gmail.com
0411 725 347
www.facebook.com/HyFloMotorsport
FOLLOW ME
keen on lca,strut brace and hydro handbrake would be sick
Posted on: 2012/6/25 11:22
Any chance of a shorter version of the standard (cable type) handbrake lever. So that original floor mounting points can be used when an S13 gearbox has been installed for CA18DET conversion, as shifter comes out further rearward in the tunnel.
Posted on: 2012/6/25 13:18
From radelaide
so u just want a handbrake just a shorten handle cadet1200
and everyone else im working on it everyday lol
Posted on: 2012/6/26 9:45
hy.flo912@gmail.com
0411 725 347
FOLLOW ME
Yep, just looking for a handbrake that will bolt to the standard mounting points and be short enough
not to foul with the shifter (needs to be approx 50mm shorter). I tried to modify a spare original one I had but ended up busting the button on the end!
Posted on: 2012/6/26 11:30
« 1 (2) 3 4 5 »
