HANDLE DOOR WINDOW REGULATOR SWAP
From Sri Lanka
Hi Guys
Can I Use b310 HANDLE DOOR WINDOW REGULATOR in B210 i have good very nice door window handle fits b310 it doesn't have a screw but fits in but it comes out of the assy while operating , what do you guys suggest to use them ? i like them
thanks
regards
sumith
Posted on: 2012/6/25 8:30
Re: HANDLE DOOR WINDOW REGULATOR SWAP
What do they look like?
B110 window winder (window crank handles) look like this
Posted on: 2012/6/25 8:39
From Sri Lanka
Hi DD
They are different from these doesn't have a screw but nicely fits to the door assy
look like this chromed and black but i feel it is from b310
thanks
regards
sumith
jpg  140.jpg (3.17 KB)
10994_4fe817ce32e4a.jpg 140X105 px
Posted on: 2012/6/25 8:49
Yes, I think those are B310 too. They use a snap-clip on the back of the handle, which engages a groove in the regulator to keep them on.
B210 uses a screw, same as B110.
Posted on: 2012/6/25 9:41
From Sri Lanka
Hi DD
Do you think that i will be able to use it in my b210 with that snap-clip ? i found them cheap so i bought them,if no way finally i can install them to the B310 but doesn't match with it's beige interior .
thanks
regards
sumith
Posted on: 2012/6/25 9:49
Perhaps. Inspect the bit of regulator that stick out of the door panel. Does it have a groove in it? If not, then only the screw type handle will work.
To remove this type of window winder handle from the B310, use a knife or screwdriver to push the clip off (insert it between handle and door panel). Once the clip is off or loose the window winder handle will pull straight off.
Posted on: 2012/6/25 10:31
