« 1 2 (3) 4 5 »
Re: EOI datto custom parts
From Nyngan, nsw Australia
all i did was moved the underneath base plate back bout 75mm (3") there abouts so it had sumthing to bolt to, works fine
Posted on: 2012/6/26 11:45
living is good,.....
I would be interested in a hand brake as well. I have been looking around for a smaller setup leaver myself to no avail. Same thoughts as to cadet1200.
When you have time see what you can come up with.
Posted on: 2012/6/26 12:39
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
From radelaide
can one of u guys throw me the dimensions for the bolt pattern and for the lenght of the shifter as my ute doesnt have a standard floor pattern anymore and ill draw something this week end
Posted on: 2012/6/26 21:44
HY_FLO MOTORSPORT - designing a new wave in motorsport
hy.flo912@gmail.com
0411 725 347
www.facebook.com/HyFloMotorsport
FOLLOW ME
I won't be near my ute till the weekend so I can't help out but interested in what you come up with. Small compact unit to pass rwc
Posted on: 2012/6/27 6:32
I have taken a pic with my phone. Can I have your number to send it to mate? It may help you out
Posted on: 2012/6/29 3:47
Dave just noticed your request. I just measured where the gearstick would come through the tunnel on my conversion and its 540mm from the rear cabin firewall (so this is the centre of the gearstick hole in the tunnel). The current handbrake protrudes around 60mm into the gearstick hole area, so replacement would need to be at least 60mm or more shorter to avoid any interference. Hopefully the pic
CA_1200_project sent you will show you the bolt pattern for the handbrake to floor attachment, the bolt holes are offset and around 100mm apart. If your real keen I could probably post you an original handbrake to model off. Also if you want some more pics PM your email address and I'll take some over the weekend.
Posted on: 2012/6/29 9:29
Hey Hotrocket, I know what your saying and that was also what I was thinking of doing, after originally searching through wreckers to see if I could stumble accross a shorter lever from something else. But a bolt in solution would be sensational and avoid the need to be drilling out spot welds and rewelding things upside down in the tunnel. I must be getting lazy!!
Posted on: 2012/6/29 9:38
From radelaide
hey guys sorry ive been a bit slack having problems with my back and a bit going on as my wifey is 32 weeks preggo
my number is 0411725347 so u can send pics there and email that i use at work and everyday is fairbairn_dave@hotmail.com so dont be scared to email me there
i have however been trying to find a handbrake in a good condition i found one but it was bent in half lol
Posted on: 2012/7/3 21:42
hy.flo912@gmail.com
0411 725 347
FOLLOW ME
I've got a handbrake I can send u if needed
Posted on: 2012/7/3 22:42
Car free
From radelaide
this would be good :)
Posted on: 2012/7/4 8:40
hy.flo912@gmail.com
0411 725 347
FOLLOW ME
« 1 2 (3) 4 5 »
