EOI.thinking of building front strut setups.way cheaper then elsewere
From Narellan,Sydney
Wondering if any1 is intrested in buying front strut set ups? Same offered from maddat but without that price tag.will use stanza struts (shortened to suit you) Pedders inserts,new Pedders strut tops and custom coilover kit.i will be building these myself so anythings changeable.thanks
Posted on: 2012/7/11 3:42
Re: EOI.thinking of building front strut setups.way cheaper then elsewere
ballpark price? Coz I might be....
Posted on: 2012/7/11 3:46
:) need a supplier?
Posted on: 2012/7/11 5:33
Car free
Can also do complete front ends, including brakes, hubs, control arms.everything you need all rebuilt and brand new Pedders bushings
Posted on: 2012/7/11 7:00
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From Goulburn NSW
Hi datrotor what sort off coin we looking at for a complete front end,what calipers will u be using,rotor size.Ajustable control arms etc.
Posted on: 2012/7/11 7:18
From Sydney
Id like to see some 45mm strut love. everyone always does stuff for stanza struts.
Posted on: 2012/7/11 8:12
From windsor, sydney
Will you be supplying a engineers certificate with them and do you have a valid product liability insurance policy and do you hold the appropriate welding qualifications to modify suspension components? This is why the maddat ones are the price they are, do you realize that if your modified component fails and is the cause of a crash/fatality you can be held liable and be sued for everything you own? Again this is why things cost what they do . Sorry to put a downer on your business venture but you must think of all the above if you are going to charge money for your parts
Posted on: 2012/7/11 8:24
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
I am qualified for welding who ever buys them can pick weather they want to go get it engineered or not.they are all up to standeds so everything's all good :) they charge what they do cause they want to not because they have to.thanks :)
Posted on: 2012/7/11 8:44
Do Australians sue over everything? Guys here do it all the time I never heard of them being sued. Although Companies do get sued...
Posted on: 2012/7/11 9:00
From Sydney
Not so much, workers compensation is the big one here, i think anyways.
Posted on: 2012/7/11 9:24
