Threaded gearbox mounts on chassis
From Sydney NSW
So my block mounts on the chassis are threaded, where the rear mount bolts up to. Can I tap these out to M10? It is a pretty enclosed space so I can't really see much thats going on. CHeers
Posted on: 2012/7/24 10:09
Re: Threaded gearbox mounts on chassis
From Sydney, Australia
Ive seen the the welded nuts com loose inside the mount, so make sure you drill the nut out with a sharp drill of correct size and use a sharp tap.
I'm sure that will work, just take it easy when you do it.
Posted on: 2012/7/24 10:37
From Sydney
I once done the same .. I just pulled the mounts off and got the nuts off and welded new nuts in cheap easy fix
Posted on: 2012/7/24 14:55
From Sydney NSW
ahhh so its a welded in nut. i'm going to try tapping it first, hopefully m10 isn't too big inside diameter
Posted on: 2012/7/24 17:00
From Melbourne, Australia
I once cut out the captive nut in the chassis rail for the sway bar... it wasn't a basic nut but a large square block of metal, assuming they are the same in the gearbox mount cups, taping them out will be fine there will be heaps of meat/strength in them still
Posted on: 2012/7/24 23:51
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Sydney NSW
great. thanks
Posted on: 2012/7/26 9:00
