Need a SR20VE
From Newcastle
I'm starting a new project build, 1200 coupe and I'm looking for a SR20VE ( in good condition) complete with wiring and ECU. Also after a 5 speed, flywheel and clutch from S13 Silvia. Located in Newcastle but will travel or freight.
Posted on: 2012/8/4 9:21
If you can't fix it with a hammer, it must be electrical.....
Re: Need a SR20VE
There was one already worked on my105.com (actually sr20 bottom, sr16ve top with quads) and if not you can get a serena bellhousing to suit a silvia box as supposedly the sr20ve is not a rwd model unless its the sr20vet from special model rwd vehicles.
Posted on: 2012/8/4 11:00
Re: Need a SR20VE
From Newcastle
Just had a look through MY105.com but couldn't find the said motor can you let me know in which section you saw it? Cheers
Posted on: 2012/8/4 12:14
Re: Need a SR20VE
From Sydney , NSW
There was one on eBay recently and was relisted a number of times. Geoff Fear at SSS Automotive is your best source of knowledge and bits for the SR/VE hybrid.
Good luck with the build!
Cheers.
Posted on: 2012/8/4 13:27
All torque, no traction
A division of "My mate's ....." engineering
Re: Need a SR20VE
From Newcastle
Thanks mate I give Geoff a call and see what he can suggest
Posted on: 2012/8/4 14:10
Re: Need a SR20VE
From Newcastle
Thanks for the information, I contacted Geoff at SSS and he has everything I need. Cheers
Posted on: 2012/8/7 10:39
Re: Need a SR20VE
Good choice! probably cheapest NA high hp Nissan 4 cyl easily converted to rwd ahead of a qr24de.
Posted on: 2012/8/7 11:45
Re: Need a SR20VE
From Newcastle
Cheers mate but I need to stay in Type 4 under 2 litre
Posted on: 2012/8/10 5:20
Re: Need a SR20VE
From Sydney , NSW
I wish .......... The new race engine isn't adding up to "cheap" but compared to some I've seen, it is good value!!
The price will be forgotten once the 200 odd RWHP hits the track
Cheers
Posted on: 2012/8/10 7:14
Re: Need a SR20VE
There is another option using an L series bottom end with worked Ka24de head but the VE is just more affordable in the end.
Posted on: 2012/8/10 11:36
Edited by D on 2012/8/10 11:56:47
