Help finding spacers
I'm looking for some conical washers or rose joint spacers anyone no where to buy?
Also after some long nuts that I can use to mount things but need to be at least 60mm long even threaded tube will do!
Also after glade nuts, or captive nuts for shocks in struts
Cheers nick
Posted on: 2012/8/9 6:28
Car free
Re: Help finding spacers
From windsor, sydney
You can get heim spacers from the speedway or off road supply shops but I find it easier to make my own that way I get exactly what I need, because I always seem to have to modify the commercial ones anyway
Posted on: 2012/8/10 22:54
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Hey wards would you be interested in making me some?
Posted on: 2012/8/10 23:21
Car free
If you can give me some accurate dimensions , sure
Posted on: 2012/8/11 11:09
WARDMAN ENGINEERING
CNC machining
0413 595 627
I have a 2 piece setup at the moment and want to make it one piece, I'm using a m12x38.5mm washer and  Rose joint spacer with these specs
Hole Bore:   0.500"    ( 12.7 mm)
Width :          0.437 "   ( 11.11 mm)
Height:          0.875 "   ( 22.22 mm)
Taper:           30 Degrees
  but I really want them to be out of one piece of good steel
Posted on: 2012/8/12 10:17
Car free
I'm going to need a drawing with the dimensions on it , that way we are on the same page before I start cutting metal . If you like I can send you a sketch and you put the sizes on it
Posted on: 2012/8/13 13:34
WARDMAN ENGINEERING
CNC machining
0413 595 627
Posted on: 2012/8/13 14:37
Car free
Perfect , what size hole ? And how many ?
Posted on: 2012/8/13 21:58
WARDMAN ENGINEERING
CNC machining
0413 595 627
M12 is the rose joint size and x4 would b grate :)
Posted on: 2012/8/13 22:34
Car free
Ok we're not on the same page yet with these spacers , what size bolt are you putting through the spacer? If you are using a 12 mm bolt that means a 12 mm hole that means the 12 dia by 8 mm section on your drawing will not exist , do you follow?
Posted on: 2012/8/14 10:11
WARDMAN ENGINEERING
CNC machining
0413 595 627
