« 1 ... 8 9 10 (11) 12 13 14 ... 20 »
Re: rocketrod's 1200
From Nyngan, nsw Australia
what's the brake line bolt thread, is it 10mm x 1m NF24?,
had look at these....
http://www.ebay.com.au/itm/150844506660?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_500wt_969
Posted on: 2012/8/6 3:04
living is good,.....
out of sight for brake lines
Posted on: 2012/8/13 9:08
fellas i need a lock for my ute fuel lid, hoo has one to sell or can you still buy new!
Posted on: 2012/8/13 9:26
cheers fella's found a new lock from Canada,
any blokes fitted or tryed to fit Gilmer gear to CA18
Posted on: 2012/9/1 7:57
Edited by hotrocket on 2012/10/17 3:01:47
new rad brackets (sickspeed) suit Honda civic, full rubber grommet with hole punch out
custom made CA/1200 heater pipes using original 1200 heat unit
Posted on: 2012/10/17 1:02
where do these two small pipes go, what runs through them water or air??
maybe to intercooler
Posted on: 2012/10/17 3:09
From Armidale N.S.W
This is lookin sweet Rod. Can i ask where you found the Radiator brackets ?. Looked on Sickspeed site cant find them under Honda Civic
Posted on: 2012/10/17 4:52
73 1200 wagon SOLD
From MOOROODUC. Victoria
the right answer is BOTH water and Air (but not in the same pipe(s))
I will go and take a couple of pics and post up what mine looks like
Posted on: 2012/10/17 5:15
big one goes directly to my bottom water pipe on my radiator
little one picks up the pipe you have on the left and also the breather on the top of the rocket cover and then goes to the air intake between MAF sensor and Plenum ....remember i am not running turbo
jpg  some pipes.jpg (148.16 KB)
8710_507e35ea4c8ae.jpg 968X648 px
Posted on: 2012/10/17 5:37
From Armidale N.S.W
Yeah DET is slightly different but there for Air/breather and pretty sure you know what the bigger one is i have DET sitting here can show you a pic if you like.
Posted on: 2012/10/17 8:39
73 1200 wagon SOLD
