« 1 ... 29 30 31 (32) 33 34 35 ... 42 »
Re: 1200RallyCar's - CA18DET 1200 coupe
From Geelong, Vic
what h190 is it your using? like a 1600 wagon diff or something?
pretty sure the bluebird or gazelle diff is the one to use for shortening. dont think there are wider h190s than them
will you even have time to break an axle between trips to the gutter?
Posted on: 2012/8/26 6:14
From Melbourne, Australia
i have the a15 vanette h190 at the moment
getting a bluey one and shortening may be my best option
your sense of humour is in the gutter.... and i won't be joining it
Posted on: 2012/8/26 11:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Geelong, Vic
i thought the a series vanettes had h165s? thought it was the Z series engined ones that had the h190s?
atleast getting a look at a bluey diff would be the way to go. whip an axle out and measure it up to see what will work. then let me know as i wouldnt mind building a h190 for the wagon at some point
you mean wont be joining it AGAIN
Posted on: 2012/8/26 13:10
yeah i thought the same pigdog. As i thought the A15 vanettes came out with the H165 4:9 ratio?
Posted on: 2012/8/26 13:19
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Lol
Now go shortened struts and shocks with Coilovers up front while u gotta change front shocks now anyways
Posted on: 2012/8/26 13:20
Car free
a12 vanette - h165 4.875:1
a15 vanette - h190 4.11:1 (23 spline axles)
the later z20 things... dunno specs except they arnt worth touching
Posted on: 2012/8/26 13:34
1200 Coupe Rallycar
so i'm starting to like the idea of the bluebird diff shorten more and more, i found i have a bluey housing and centre, but no axles
anyone know if the housing is the same for 23 and 29spline? may be able to retain the already modified housing and upgrade with bluey centre and shortened bluey axles, but that may be wishfull thinking
Posted on: 2012/8/28 13:31
1200 Coupe Rallycar
just found out my mate has the axles from the diff i have... sounds like i may well be in business
Posted on: 2012/8/28 13:36
1200 Coupe Rallycar
you learn something new everyday!! new diff sounds good! are you going to do a half strip down and rebuild the ca as well???
Posted on: 2012/8/29 1:01
1200 Ute - Mild A12
From Geelong, Vic
so what makes the z20 vanette diffs not worth touching? wouldnt they just be a 29 spline h190?
housings should be the same, the carrier is the same im pretty sure, so i cant see why the housing would be different. would just depend on what wheel bearings they use, whether they are the passenger car ball bearing type or the industrial taper roller type
Posted on: 2012/8/29 1:13
