Low Oil Light Coming On @ Idle
Hey guys, I removed my oil pump on my a15 this afternoon to replace the leaking gasket. Cleaned it all out with degreaser and all that.
Now i refitted it and the low oil pressure light comes on the dash at idle and low revs.
I have since removed the pump and refitted it multiple times, still does the same...
I have dismantled the pump, and everything is like new.
Does anyone know what the problem could be?
The engine was apparently rebuilt about 20,000km ago.
Maybe i need thicker oil? ( I use 15w-40 and change it regularly )
Does anyone know what Pressure in PSI the light comes on at?
Ive read that anything below 10PSI at idle is dangerously low.
Any help would be great
Posted on: 2012/8/30 11:31
Re: Low Oil Light Coming On @ Idle
From Adelaide
Hooking up a pressure guage to the oil sender hole might be a good idea to see what it's actually doing. Have you checked the clearance between the housing and pump rotating parts? Has this problem started after changing the gasket? Could be as simple as the gasket is too thick....
Posted on: 2012/8/30 12:22
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Yeah after i changed the gasket. I used standard ACL gasket paper
Posted on: 2012/8/30 13:06
Did u prime pump before fitting? Maybe an air lock
Posted on: 2012/8/30 13:17
Car free
From Melbourne, Australia
yeah had same problem when i didnt prime new one, tip some oil in the hole and turn it over by hand before installing
Posted on: 2012/8/30 13:18
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Thanks guys, tried it this morning.
Works fine now that i primed it
Thanks
Posted on: 2012/8/30 22:37
