(1) 2 3 4 5 »
silvia brakes on 120y strut
From adelaide hills
can anyone inform me if i can fit 280mm rotors and calipers using the same adapter bracket as 250mm caliper? Or is there a differenceother than obvious size between the 250 and 280 caliper? Cheers
Posted on: 2012/9/22 1:16
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: silvia brakes on 120y strut
im currently putting together the 250mm conversion but ive been told its the same adapter bracket for both so you'll be fine.
makes sense really. on the s13 only the breaks are different not the struts so the mount will be the same
Posted on: 2012/9/22 3:21
1200 coupe
From Sydney, Australia
yes 100%
Posted on: 2012/9/22 4:55
B110 sedan
From Sydney
Depends who made your brackets, it they were designed for the 280mm setup you will probably have to grind away a bit of metal on the inside radius if you want to run the 250mm calipers.
Posted on: 2012/9/22 13:29
From Trinidad and tobago
Could i get some help?What are the 250/280mm rotors off? Need to up grade my brakes..
Posted on: 2012/9/22 19:30
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From Melbourne AUS
They are from japanese import s13 silvia & 180sx
Ive got a pair of the 280mm s13 calipers and discs that I will sell
if anyone needs them.
also got a pair of the 250mm discs which are slotted if anyone is interested in those
they have been run with qfm a1rm pads and will need machining to run any other pad
pm me
Posted on: 2012/9/22 23:06
Edited by ANGE on 2012/10/4 13:05:58
1973 B110 A12
From gold coast aus
think 250mm s13 ca18
280mm s13 sr20det
Posted on: 2012/9/23 4:28
From Armidale N.S.W
The brackets if the kev rowley type work with both types of discs and callipers. I ran the same pair on both we went to the 250mm to have more options from our wheel selection.
Posted on: 2012/9/23 7:40
73 1200 wagon SOLD
Hey again,Running 13x7 wheels which would be better for me 250mm or 280mm?
Posted on: 2012/9/24 5:03
Street Sleeper!
From Sydney
250mm
Posted on: 2012/9/24 5:15
(1) 2 3 4 5 »
