« 1 ... 11 12 13 (14) 15 16 17 ... 28 »
Re: DEMAC's 1200 UTE
From MOOROODUC. Victoria
97db on accel and "well over on backoff"
what was the allowable reading... the guy in Mornington says 96db at 4500 rpm
Posted on: 2012/10/1 7:22
Yep same. Subaru muffler got me under but failed rwc lol.
Posted on: 2012/10/1 8:45
the guy doing the test told me that I should either try a new cat converter or replace the 2.5 inch (65mm) exhaust system with a 2.25 inch (57mm) system
Posted on: 2012/10/1 8:49
From Melbourne, Australia
cool! progress!
my 2.5inch system blew over 100
exhaust place made a cheap 2inch system to JUST pass the 96dB and get engineers, then 2.5 goes back in
Posted on: 2012/10/1 8:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Get a choking cat and a 2inch diff back maybe to drop resonance. But piggy got his to pass as 3inch almost I think.
Either way make it flanged and you can swap either of them out
Posted on: 2012/10/1 9:10
the cat is the most expensive part, changing them around is gonna cost
Posted on: 2012/10/1 9:21
1200 Coupe Rallycar
Yeah, I just had a look at online prices $400 just for the cat - yikes
I think a smaller diameter pipe may be the go
Posted on: 2012/10/1 9:24
Surely a 2nd hand cat is fine for EP @?
Posted on: 2012/10/1 9:35
checked the cat ... it is actually in good order - the inside is full of the stuff you would expect
so now have to find another legal way to make it quieter
in the mean time I replaced the front shockers got some pedders gas for $250. Also replaced the bailey channel felt rubbers that the windows wind up on. replaced all the rubber brake hoses and fixed a rocker cover oil leak.
Holidays are over and i have run the car for about 200 kms on a vic roads permit. still smells a bit from burning off oil and stuff but going better.
a few things to finish and tidy up including some minor coolant leaks, the noise factor and too much play in the steering wheel. also the speedo decides when it wants to work and when it wants to sit on 70 kms - i need to recheck the wiring and the cluster (hopefully don't have to take out the dash yet again)
Posted on: 2012/10/5 10:30
Maybe we can both hire 1200rallycars 'quiet' exhaust to get us through the noise test once he's put his 2.5 inch system back on?
Great to here your on the road..even if it's on a permit.
Posted on: 2012/10/5 15:32
