wheels alignment
From Goulburn NSW
Hi guys hit a massive puthole doing 100km now the car is pulling to the right will a wheel alignment fix this.Also the wheel has been pushed back,i have cheached all the casters an other thins an nothing seems to be bent.
Posted on: 2012/10/2 9:45
Edited by mcdat on 2012/10/2 10:02:12
Re: wheels alignment
From SA
Sure will buddy !!! It's a start anyways
Posted on: 2012/10/2 10:11
From Sydney
If the wheel has been pushed back, something must be bent.....Has the mount for the caster rod been ripped off the chassis rail or at least deformed?
Posted on: 2012/10/2 10:16
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Goulburn NSW
checked that benny still in place and welded.
Posted on: 2012/10/2 10:22
My car pulls to left after wheel alignments has for ages. Have replaced all bushes and nothing bent or ripped. Should I wind more caster into left side to pull wheel forward more? (have adjustable caster rods)
Sorry thread hijack but I reckon you bent something at 100kmh
Posted on: 2012/10/2 10:31
From Melbourne, Australia
if the wheel is back and the castor rod is in-tact then the only other thing it could be is bent chassis rail, look between where the engine crossmember bolts up and the castor rod mount, should be dead flat. A give away of this being bent is that the swaybar mount will look mounted on an angle also. It's a problem my rally car has, it's bad enough the swaybar touches the sump at the front of the motor
Posted on: 2012/10/2 11:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Goulburn NSW
Well guys took it to get a wheel alignment was put on the hoist and worst scenario the chassie rail is split and slightly bent althoughits still driving alright apart from the going right when the hands are off the steering wheel.
Posted on: 2012/10/3 6:36
From Sydney
Split chassis rail = ticking time bomb. If it fails completely, anything could happen and you may lose control of the car endangering yourself and others. Get it sorted ASAP.
Posted on: 2012/10/3 7:23
1970 KB10 Coupe
S13 caliper b...
From Goulburn NSW
Hi guys is 1500-2000g the wright price to get it fixed.thats what ive been quoted also do i need an engineers cert after its been fixed.
Posted on: 2012/10/3 8:35
too expensive, i got quoted 1500 to cut the entire front off the rally car and weld another on
no engineer cert required, unless maybe you put it through insurance and they try to write it off
it will cost a bit as they will have to put it on a rack to make it square, but surely you can get out of it for less than a 1000
Posted on: 2012/10/3 8:46
1200 Coupe Rallycar
