Dato a12 cam wanted
Hi looking for a nice lumpy a12 cam & lifter will be running twin 40 dcoe webbers on a rally car im building can anyone help out please cheers
Posted on: 2012/10/4 11:36
Re: Dato a12 cam wanted
i have an early model a12 cam but its not exactly lumpy, had it done by wade cams in melbourne. I have the same one in my mild a12 with a single 45dcoe and the idle is fairly smooth and fast. If you have a standard one you should just be able to have it ground to what you want.
Posted on: 2012/10/4 11:59
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From Brisbane
I have a new reground camshaft here that I'm not going to use, specs are very close the Ivan Tighe 140 profile, rev range, 3500 - 7500rpm.
http://www.tighecams.com.au/cars.htm
I have a set of lifters here I can get refaced to go with the cam.
It's a two gear drive camshaft, not single drive.
Just let me know.
Posted on: 2012/10/4 12:52
