« 1 (2) 3 4 5 »
Re: silvia brakes on 120y strut
From adelaide hills
what did you have on yours ben? whats the smallest wheel to fit on the 280mm, ive got 15's atm but eventually wouldnt mind getting some wide 13 or 14's
Posted on: 2012/9/24 10:22
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
From adelaide hills
and do you need to modify the hub at all?
Posted on: 2012/9/24 12:59
From A-TOWN
You need to machine a few mm off the hubs, helps if you have access to a lathe, also press the studs out of the silvia hubs and use them in the datto hubs as they are longer, helps if you have access to a decent press. I run the ca18 rotors on 14s with a fair bit of clearence.
Posted on: 2012/9/24 13:11
From Sydney
I have recently made up a set of the caliper brackets for this conversion, for another member of this forum and have another four sets available, as laser profile cutter like to do sizeable runs rather than one off's. So if anyone is in need of a set, drop me a PM.
caveat: I can supply these brackets for use in motorsport only, if the buyer uses these elsewhere, I will not be held responsible or liable. Please make your own assessment and judgement for suitabiltiy on your vehicle on the street.
cheers
benny
Posted on: 2012/9/26 12:18
Edited by benny on 2012/10/11 7:00:20
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Nyngan, nsw Australia
pm-d ben
Posted on: 2012/9/26 20:18
living is good,.....
PM sent
Posted on: 2012/9/29 13:55
From Trinidad and tobago
Sorry for the hijack..But does any one have the dimension for the custom s13 bracket used on the 120y strut for brake mods??
Posted on: 2012/9/30 2:17
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
From Sydney
pm's replied.
edit, also a couple of pics for reference and quality of manufacture.
cheers
Posted on: 2012/10/4 10:37
Edited by benny on 2012/10/5 1:31:36
Edited by benny on 2012/10/8 6:00:59
1970 KB10 Coupe
S13 caliper b...
thanks Ben, what that combo you have there?
cheers Rod
Posted on: 2012/10/11 3:44
From Sydney
B110 struts, b110 hubs, 250mm S13 rotors and matching calipers. Wheel is a 13 X 7 Watanabe.
Posted on: 2012/10/11 3:48
1970 KB10 Coupe
S13 caliper b...
« 1 (2) 3 4 5 »
