280zx struts in the 1200.
Quite a regular
For the ones who has the 280zx struts in their 1200s, im just wondering if the strut height is sufficient for a well lowered 1200 running 13's or should i shortened the strut.. so it won't bottom out. I know the struts are already shorter than the standard 1200 struts but just want to see what people have done and their opinions.
ALSO has anyone experienced inverted shock inserts?
thank you!
Posted on: 2012/10/23 10:12
Re: 280zx struts in the 1200.
From Sydney
thank you!
Bilstein P30's, if you can find them to suit
Posted on: 2012/10/23 10:17
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Whats a set of bilstein shocks to suite stanza go for?
Posted on: 2012/10/23 10:20
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From Newcastle
Hi these are the 280ZX struts I'm running on my coupe rally car also running 14" wheels.
jpg  1200 v 280ZX.jpg (106.06 KB)
13276_5086fe01667e6.jpg 567X756 px
Posted on: 2012/10/23 21:30
If you can't fix it with a hammer, it must be electrical.....
Are you planning on lowering it more than 4 inches?
Posted on: 2012/10/23 21:53
Quite a regular
Cheers fellas, I forgot how much I lowered it but I'm running 14" ATM and it just tucks.. If I recall it was 3 inches?
Project was on hold, now trying to start it again.
This is how it sits now, i got 13x8 and 9 advan A3A's that i want to run. 280zx reduces track so the 8 might tuck in better at the front. Also trying to avoid bump steer
jpg  _DSC4574.jpg (116.61 KB)
15150_5087aedc64c26.jpg 640X426 px
Posted on: 2012/10/24 9:52
Edited by srdatsun on 2012/10/24 10:07:55
The 280ZX struts increase the track slightly, don't they?
But the track also depends on which ball joints are used. If they used an late B210 LCA/Ball joint, no increase. But if they used a B310 large Ball joint, it increases track.
Posted on: 2012/10/25 7:23
Quite a regular
Hmm anyone can confirm?
I guess talking from stock brakes and all. forgpt to say my lca is b210 and ball joints? I really need to check. with 280zx hubs, they sit closer inwards towards the strutwhich was what i wanted, im running s13 brake conversion so big difference in hub offsets?
Posted on: 2012/10/25 11:24
